Nice Face, Shame About The Hands!
Dear all,
I have just finished this nice Allaine, which has a Felsa 1560 movement. After a few hours I noticed that the hour hand is misaligned. Could this be the cannon pinion at fault, or something else. I originally set the hands at twelve o'clock.
Thanks.
P.S. Yes, it does need a new crown!
Check the washer under the dial. If there is none or it is not stiff enough, the hour wheel might not engage properly with the intermediary minute wheel (that is turned by the canon pinion) and so it would be left behind.
Also make sure the hour hand doesn't slip on the hour wheel. Or maybe it stumbles upon an hour indicator on the dial.
Edited by matabog
I'm with Bogdan on this one. If the hands are going out of sync with each other, it is either a gear issue or one or both hands are too slack on their corresponding arbours.
If it was the canon pinion, the would still be in the correct position regarding one another but the watch could lose a lot of time through slippage.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
