I was lucky enough to recently acquire a Boley F1 lathe but the belt is needing replacement.  Does anyone out there know where I can purchase belts for this type of lathe.  The belt I have is round rubber 3.5MM diameter with a total length of 265MM.
Any help is appreciated.
Thanks,
Bob
Most of us use polyurethane belts nowadays, although there are sone who swear by leather belts.
You can get a unjoined length, cut it to size and fuse the ends together. There are plenty of videos on YouTube showing how it's done.
SG$ 0.51  26%OFF | 1 Meter Green Orange Polyurethane Conveyor Belts Round PU Drive Belt Meltable Cord Dia 1.5/2/2.5/3/3.5/4/5/6/7/8/9/10/12/15/18mm
https://a.aliexpress.com/_mtdizee
That sounds like it might a sewing machine drive belt.
Just Google "3.5mm rubber sewing machine drive belt" and see what comes up.
Hector,
I have seen the videos on joining the polyurethane and looks easy.
I ask this one question out of ignorance.  Does poly have a stretch to it?  I was assuming the belt should stretch to help with vibration.  If it doesnt make a difference I am in with polyurethane.
Thanks,
Bob
Hi polyurethane belts have a little give.  Move the motor to the closest position then fit and join the belt. Method I use to cut it slightly over size, fit the belt over the lathe pulley, heat a blade and press both ends of the belt on the blade and when melting slide off the blade and press together. And hold untill cured. Then fit over the motor pulley and adjust the tension. Do not over tension as it outs strain on the join.
    • Thank you very much for the very helpful info, folks. A lot of reading to do! I do like the look of that ingersoll. I am in the UK, so I think moebius is more readily available than Elgin. I hear 8000 does the trick as a jack of all trades. Given the rather sorry state of the Benrus, if I get the movement to run (If wound, it ticks for about 2-5 seconds then stops. Give it a tap, it ruins again, then stops again), What are the chances that I'll be able to fit it into an ST36 case (perhaps with a 3d-printed adapter)? I don't think I'll have the spare cash to invest in case re-plating and dial re-finishing! I would really appreciate some info/links on how to clean the parts: is it achievable without a ultrasonic cleaner, or am I better off buying one and not wasting my time? Also, can I get away with a timegrapher app on pc/phone?
    • Welcome from a few miles south.
    • I have serviced one Luminox in the past.  As I recall, the hands were really tight.  Also, because of the tritium tubes, they sit proud, so when using normal hand levers, you may not get enough leverage.  You need to protect the dial from scratches, so use thick paper or plastic under the hand lever.
    • Hello, I am in the process of assembling a jughams 09 clock. Everything has fine except the warning wheel pin is on the underside of the warning wheel. The lever which activates on the pin is settled on top of the wheel which I understand is not adjustable. If the pin was uppermost I can see that it would work properly. I feel that either the pin is on the wrong side or the wheel has been removed in the past and been put back on upside down. Any help would be most grateful.
