Loose minute hand
Rixy
I have been working on a Garrard Westminster chime mantel clock (1955). Have managed to clean it an reassemble it but the minute hand is very loose and the part that fits over the minute arbor pops out easily. Should I fix this with super-glue or is there another way? Have added a photo if that helps.20230325_172552.thumb.jpg.7b42131b1f7f9ed361b7f148ef913998.jpg20230325_172424.thumb.jpg.c5b4df23bbb874fa9e8b6da90d6f8376.jpg
I wouldn’t superglue it personally but I am not a clock person so can’t really give much advice. I would suspect though that it would be more about peening it with a staking set to fix it together. Hopefully @oldhippywill be along with some proper and professional advice.
Tom
Hi  I am afraid no glue.  the boss needs peening to tighten it up on the minute hand But don't tighten it hard up just yet , just enough to hold it in place. when the clock is finished and the hands are being fitted the position of the bush may need adjusting to bring the hands into line, reason for not tightening it up too hard. To do that fit a square file or mandrel into the hole and move the hand so as to line up. when its correctly aligned then tighten further but not over tighten as you may split the hand or the bush.
Modern glues are fantastic, so why not?  I'm not disagreeing with you, I just want to know why.
Hi the reason for not glueing it is the need for adjustment, yes modern glues are great but not for bodging clocks. You my need to make a punch or stake to enable you to do the job or both. I have done it. Using a flat plate before but the staking tool makes it easier,, half the fun is improvising and learning new skills.  If you spread the bush a little enough to hold the hand you may have to file the square again to fit the center wheel arbour. It needs care and do not rush it.   Cheers
There doesn't look as if there is enough to rivet over. But give it you best shot. Do you have the tools to make one? if so do so. I see the others are against gluing but in your case if you can't make one and riveting doesn't work you are left with gluing. Make sure you clean it first before you glue it.
You could try here. He is on youtube. Just type in Elliott Clock repairs. He even appears on T V on some antique repair program.
Specialists in Elliott Clocks 14 Langdale Court Witney OX28 6FG
I managed to peen it with a 1/8" punch. As suggested, I did it a little bit at first so I could adjust it and then when happy, firmed it up. It didn't distort the square hole so no need to file.
Time to reassemble!
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
    • I actually sent a message to him on eBay asking exactly that. They all look like snap-on casebooks so should be easy enough to get the photos.
