Tap And Dies
Here is a little query that is probably painfully obvious to those in the know but puzzles a tinkerer like me.
Got myself a little Anchor Tap and Dies set and although I have used the taps for re threading holes I have not had cause to put a thread on a bit of wire or create a screw if you like.  Can anyone educate me in simple terms on the use of the plate and in particular what the arrowed doubled holes are for.
Are they the actual cutting holes and the single hole opposite the one to check the thread in, I can't see how the double hole is utilised.
Cheers,
Vic
Cheers,
Vic
You're absolutely correct Vic, the split forms the cutting edge.
Is this one of those Indian made sets? Are those any good? I've used cheaply made (Indian or Chinese) three-flute small taps before, and they were horrible.
The Indian ones I've seen for sale are too cheap to be decent, I suspect..
I agree with George,
I think mine just cost in the region of £14.95, Red rooster sell the same set boxed up for a bit more (£18.95).
I got them as I needed one size to do one job and that was only resizing a stripped out hole on.  It worked ok but I was extremely careful and they now reside in the back of my tool box awaiting the next emergency.
As I just tinker I am not likely to use them often, if you are expecting to be using them often, I would probably buy a better set - those do however come at a premium but like everything else you have to balance things out - you can buy a decent Omega for the same price as a Bergeon set !.
Cheers,
Vic
Hi Vich,
the other thing the hole is useful for is inserting the blade of a jewellers saw through when you shear of the wire you are trying to thread :-)
The most successful technique I've found is to hold the wire in a collet in the watchmakers lathe (put a good chamfer on the end), hold the die plate at 90 degrees to the wire using a tailstock tube to support it.
Lubricate the wire with a light oil or cutting fluid
turn the headstock by hand whilst putting pressure on the tailstock and die plate,
only turn the headstock spindle a quarter turn, back off a half turn, repeat
Once you have cut about two whole turns, back the die plate off the wire altogether, clean out the die
thread back on and carry on cutting.
I started out with brass wire (trying to make a banking pin for a cheap pocket watch) and snapped the wire off in the die more times than I care to admit, with these cheap die plates it trial and error and practice, practise, practise. The main problems I found with the finished result were the thread form was poor and as the die plate has a chamfered lead-in on both sides and so forming a thread up to a shoulder is not possible. I expected the plate to have a chamfer on one side and be flat on the other side, but all the ones I have (you end up buying another whole set when you snap the tap off trying to clean out the die) are chamfered both sides :-)
good luck
Sean
I know GEO, I know :) but it was the only way I had at the time to get the mangled bits of brass out of the plate. After much practise I learned to saw through the wire 3/4s of the way, then use a screwdriver to unscrew the sheared wire.
can you remove some metal off one side to remove the chamferred cutting portion?
Anil
It should be possible, but you would require access to a surface grinder to do it accurately.
I wonder if a small end mill would give a good enough surface on the plate?
The plate will be too hard to cut with an endmill unless you draw the temper out and re-temper the plate afterwards. I really think the only practical option is to have it surface ground. Another good thing about surface grinding, the plate will be held perfectly flat on a magnetic chuck. You will have to de-magnetise the die plate afterwards.
    • The problem is that this movements were not produced with the modern level of standartization, there for parts from one didn't fit well to another, even if they may look the same. May be it doesn't concern the winding stems, but yet there are not spare parts for such movements in supply companies, not even clear calibre identification possible. And where calibre identification  is possible, there are no Ronda numbers for the balance staff or the winding stem for this calibers in the data bases.
    • That black stuff - I had similar things happen with evaporust!  In that case I understand the evaporust eats the iron oxide away without hurting the metal but it can leave behind a layer of carbon which was in the steel that got oxidised. I spent ages trying to perfect a cleaning regime with various different stages in jars in an ultrasonic bath. In the end I switched to washing all but the balance and pallet fork in IPA and gently brushing it with a small artists brush.  I would estimate that I have found an extra 20º of amplitude doing this! It also takes me no longer than waiting hanging over a tank to move stuff to the next jar If it is really bad then I have used the IPA as a prewash and go through my old routine
    • I thought is FHF. Sounds good to make winding stem by myself but I am not in watchmaking on this level. 😄
    • At a friend's request, I've obtained a key for her long case clock which has been silent for some years. On winding it, the weight only rises a foot or so from the floor - & is not visible above the lower panelled section - before the key meets significant resistance. However it then runs quite happily for a day or so by which time the weight is again on the floor. I haven't had the chance to examine the movement but would be grateful for suggestions as to what might be happening here.
