Servicing My First Chronograph!
This i a wonderful thread and a great forum. It's such a pleasure to see enthusiastic and positive feedback for this restoration. As a clock guy who has been slowly learning watch restoration in the past 5 years or so, I find that the parent videos and this forum give me a boost.
I'm looking forward to seeing a pic of the watch ticking away!
Dean
Dean
I am just waiting for the arrival of new balance wheel and incabloc to finish the job!
I'll report when the Cauny Chronograph will be ticking again.
Hi GuiBer, how is the Cauny going?
i hope next Monday I can finish it.
The parts (balance wheel and incabloc) have already arrived,
Unfortunately I don't have the proper tool to take out the old incabloc from the balance cock and put the new one in place, and so today I had to ask for that task to a professional watchmaker, who accepted the job with some reluctance!! Despite we are not absolute strangers to each other as we both live in the same small town, he didn't show any interest in showing me how the work it's done. He just told me: "come back for the part next Monday!". I think he is "afraid" that I can become a competitor (!!) to him, although I have told him that this is "only" my new hobby!!
Not yet good news!
The watchmaker to whom I asked to change the incabloc (I gave him a new one) in the balance cock didn't do what I asked.
He ( I don't kow why!) just didn´t do it and decided to take the old incabloc out and just put a new spring on it!
Futhermore when I tried to open the spring with maximun care, as soon as I barely touched it... it flew away! I am almost sure that it was not properly fitted!
I simply decided to forget this watchmaker(?) and perhaps invest in a tool to do myself the work.
What do you advise?
Yours don't need a special tool GuiBer, you should be able to install the spring and the Incabloc using tweezers. I find a jewel "picker upper" is a nice easy way to pick up and position the cap jewels.
Have a read of this thread to see what a "picker upper" looks like. http://www.watchrepairtalk.com/topic/1385-best-way-to-pick-up-jewels/
Thanks Geo for the information.
I have read the post, but indeed it doesn´t answer my doubts, as my big concern is how do I take out from the balance cock the incablock setting that, I suppose, is "press-fitted", and how do I install the new one in place?
Hi Geo, I want to remove the incabloc because it's impossible to fit a new spring to it without taking it out of the balance cock. And as I have a new one, I think it's much better to fit it than putting back the old one that can even be damaged after the many attempts of putting a new spring into it.
Well, some good news! The Cauny chronograph is ticking again (although it needs to be regulated)!
When I was inspecting more closely the incabloc after having lost its spring as I told in a previous post, I noticed that the "gap" for inserting the spring was larger than before I left the balance cock in the watchmaker!!
So, I am almost certain that he didn't take out the incabloc, and just "scraped" it so that he could manage to insert a new spring!!
And of course, if it's easier to fit a spring in, it's also easier that it flies away when you touch it, and this was in fact what happened when I tried to open it for putting the jewel in place!
Now, after some attempts I already manage to put a new spring, the jewel inside and close it, but of course I am not confident that it will not come out any moment with some more rough movement or stroke. So I prefer as soon as I have the proper tool, to change the incabloc for the new one, (what the watchmaker should have done, as I asked him!).
Nevertheless it is working, but it needs very much to be regulated, as it is running fast 9 m/day. Of course this is quite normal, as I also changed the hairspring, and it is certainly out of beat. But I think it will have to wait some time, because for that I also have yo invest in a timing machine!
Although all the problems and surprises during this my first service to a chronograph, which I overcomed with your help, I am pretty happy, because I could hardly imagine some weeks ago that I could do it!
So for the time being here there are two photos of the Cauny waiting for the final touch:
post-1304-0-02408200-1441905025_thumb.jp
post-1304-0-67570600-1441905094_thumb.jp
That is a very nice Cauny Chronograph, if I can tell you my opinion, and the fact that you managed to put it back to work is really a bonus. Is the chronograph function working good, by the way? In the movement picture it looks like the hammers are zeroing the hands, but the coupling clutch wheel is touching also the chronograph runner for the seconds... If I compare it to my Valjoux 7733, they are a bit more far apart when the chronograph is not running...
The chronograph is working fine and its buttons are much more smoother to actuate than before. The coupling clutch wheel is very near (but not touching) the chronograph wheel, Comparing the last photo with the one I posted before servicing the watch, you can see that now the clutch wheel is in fact a little bit closer, but I didn´t notice so far any problem with it. The distance between the wheels can be regulated by the cam in the end of the arm that carries the clutch wheel. Do you think it would be better that I give it a little adustment?
What really is not so good is that the watch is running very fast (9m/day), but I think the reason is the new balance wheel I installed, not caring for the moment for a correct beating adjustment. I just tried some adjustments on the regulator but in this situation it has almost no influence in the timing. Is this normal?
I intend to come back to the problem when I''ll buy a timing machine ( I hope I can do it not so far from now !).
The most important thing is to set the depth of engagement correctly. Make sure that there is a little backlash on the gears by ensuring that the gears are not fully in mesh. If you do this, the disengaged clearance will take care of itself.
Thanks Geo for the information. I tried exactly to do what you say as I have read about it in the Valijoux technical document concerning 7733 movement.
I came back to my Cauny today, although I have not yet a timing machine to help regulating it.
Looking with more attention to the new hairspring I had fitted to the balance wheel I noticed that the outer coils were very near each other and that this could be the reason for the wacth running fast (about 1m/hour).
I thought the hairspring could be magnetized, so i demagnetized it (several times!).
It keep the same shape so i decided also to clean it as it could be sticky with oil or something. I used lighter fuel as I don't have a more suitable cleaning fluid.
After drying it and demagnetizing again, although I didn't notice any change in the clearance of the coils, I put it back on the movement, but the rate of the watch is exactly the same as before!!
I also noticed that the outer coil after passing the regulator is too far from and not concentric with the other coils!!
Can you please help with some advice about this situation? Thanks!
(here are two photos so that you can have a better idea of  the abnormal configuration of the hairspring)
post-1304-0-67754400-1443713099_thumb.jp
post-1304-0-28520500-1443713134_thumb.jp
GuiBer, I checked mine, and altough not as extreme as yours, my hairsring is decentered too, but I have not noticed that great loss in time (I have no timer either...).
I am thinking to takle the issue this WE if I find some time, and straighten it a bit with my tweezers
Edited by GeorgeClarkson
The hairspring regulator arm does seem a long way from the end stud arm.  It just might be a mile out of beat.
Without the aid of a timing machine to give a reading this is going to be difficult to analyse. You could visually check the position of the impulse jewel when it is in it's static position. However to check this you will probably have to remove of the train wheels bridges etc.
Good news ! ... and thanks for your help GeorgeClarkson and clockboy!
I released the boot on the regulator, positioned again the outer coil on it and "closed" it.
I put again the balance wheel on the movement and after several attempts positioning the end stud arm and the regulator (alternately), I finally managed a position with which I got a 2s/hour fast rate!
I think I'll leave it by now as it is, and I'll come again to it when I'll have the timing machine!
Here is a photo with the final position I got which is indeed very different from the original one:
post-1304-0-67154700-1443738610_thumb.jp
Edited by GuiBer
A great improvement but 2 sec an hour is still one minute a day. I suggest you wait until you get a timing machine before any further adjustments are made. You will then be able to adjust for Dial Up,Dial Down,Crown Down etc etc.
    • Hi @Roll1ex, welcome to the forum. It's considered good practice to introduce yourself to the forum in this thread: https://www.watchrepairtalk.com/forum/23-introduce-yourself-here/ But no worries. I don't have the spec sheet for the 15xx movements, but when I look at the 31xx information, it stands out that the endshake of the rotor should be between 0.01 and 0.03mm. That is LESS than the pallet fork and the lowest of all endshakes in the movement. Not exactly sure what you mean by that. The rotor itself is a unique part which doesn't have different heights. If you mean the height at which it is installed vis-a-vis the automatic bridge, then yes, that can be adjusted a bit via the two jewels that hold the rotor axle. Height differences vis-a-vis the bridge can also be caused by the strength with which the new axle is hammered/riveted into the rotor. And yes, that can be compensated a bit via the jewels.   This would probably indicate that the axle isn't perfectly perpendicular to the rotor. That could explain why the weight is closer to the rest of the movement at 9 o'clock -- it would then be furthest at 3 o'clock. That would be bad news. A new axle should then be installed... and properly this time.   As I wrote already, there is margin for adjustment via the jewels. As for the spring clip, the 15xx movements only seems to have one spring clip thickness (part 7911 - https://www.cousinsuk.com/PDF/categories/2878_Rolex 1530 Pages 6-10.pdf). The later 31xx movments have several versions with different thicknesses. But there is a good chance that the clip is worn (=thinner than it should) and should then be replaced.   But, in conclusion, if the rotor hits the caseback in one particular postion, then my first suspicion is that the axle wasn't punched in at a perfect 90° angle. That must first be re-done correctly. No other fixes will be solving that problem. Furthermore, if the rotor "dings" against the caseback when the watch is shaken (but not in other situations), then there is likely also an issue of endshake (more an issue of the jewels) or lateral play (more likely the sping clip).      PS: by whom? Independent or RSC?
    • Morning OH, absolutely not, that has never been the intention, there does seem to be a lot of emphasis placed on that point. Its only a contact storage location. Honestly OH , i cant get my head around why anyone wants to think why members would be pulled away from a forum that works so well. Your fear of losing the forum OH is exactly the same as everyone else's. Hopefully it will wont happen for a very long time, but not having a back up would mean that everything would be lost if it ever came to that. Scott has set that up for anyone that wants a failsafe,  if they are not comfortable with it then of course they dont need to participate. Its entirely of their free will.
    • Wow what a difference. As long as you are happy with the set up and it works for you it makes no odds. The belt is in line with the pulleys so no problem there.   No questions are silly on this site.
    • Hello and welcome from Leeds, (Rothwell). Originally from Allerton, Bradford.
    • What is this going to be used for. I don't want to be part of anything that will drive traffic away from here.
