Rectangle And Non-Standard Crystals
Mkay
Hello everyone was just wondering what kind of tools people are using for non standard crystals.
Currently I'm just taking a round crystal and some pilers and just snaping chips of crystals off untill i have the shape im needing. then I'm using my gem faceting machine with a rough diamond wheel to get it in the right shape then a finer diamond wheel to polish the edges so it fits into the watch.  Using a glass cutter is also fine for the more square/rectangle but once u get into a heart shape or oval it gets a little more tricky. This method works fine but its a no fun having crystal fly around as u are chipping it all away. and would take even longer if u try to grind all the extra glass away on the glass grinders.
How are others getting custom crystals made?
Any tips for this raw amateur would be great
thank you
here are some photos of what I'd ended up doing hoping for a more efficient way.
This is used to polish and cut gem stones.
A tool I got from my uncle, this is what he would normally use to cut crystals, but i decided to use the gem faceting machine instead since i already had another assignment that i was working on.
The watch that needed the non standard crystal
Traceing the round crystal and then chipping away (the crystal is still much larder then what it needed to be)
After cutted and fitted.
The other watch that needed the new crystal
Marked and chipped away
Havn't had a chance to finsh this yet since its getting late but ill post more once its done
Just finshed the square watch here the rest of the photos.
Outline. and then chipping away the glass photo can be seen aboved. ended up having to start a new one since i over cut one of the corners.
Over all this took a good bit of time, about 5 broken crystals but being that this was my first time doing custom crystal i think over all it came out well, happy to put my name on this and return it to the customers. with more pratice i hope to do this much quicker. and maybe someone will have some tips or others tools i'll be able to use to make it quicker.
As a side not how much does this type of work normally cost? Currently im charging 45$ CAD retail for this.
Edited by Mkay
Good job, Mkay. The method you used is similar to my friend's who is doing by dozen daily.
The machine he used is as shown in the picture.
You'll need to stock up on different types and shapes of crystals e.g. single-domed, double-domed to meet the needs.
I'm planning to get one for my shop too.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
