Greetings fellow horologists
Stagesmith
My name is Ernie.
I work as a building inspector in Seattle.
I have a background it many, many, many skills.
Blacksmith, welding, knifemaker, gunsmith, machinist, jeweler, glassblower, potter, foundry, carpenter, leather work, metal spinning.......
Lots and lots of skills.
Started watching Marshal's videos on youtube as Wristwatch Revival.
I remembered I had a pocket watch that had been broken for years, and would love to make it live again
Started acquiring tools and stuff, then bought a bunch of broken movements off eBay and began tearing things apart.
The broken watch I have had all this time is a Hamilton 975 I got for my High School graduation back it '83.
Chose it because of the lovely movement.
It got broken because I carried it in college and had a bad habit of catching the chain on things like lathe crossfeed handles.
I began this adventure winter of '22 and have dubbed it my winter hobby.
I think I have around 30 Hamilton movements now, and a smattering of others.
Definitely staying with pocket watches.
I did manage to fix my Hamilton 975, and also a larger 18s Hamilton.
Eventually I need to start casing the ones that work and kicking them back to eBay.
I have a long standing habit of not waiting for tools to become available and I just make them.
So far for watchmaking I have made a size 12 mainspring winder, a staking tool, and an oiler caddy.
You can check out my Flickr gallery to see all the silly things I build.
https://www.flickr.com/photos/129065511@N02/albums
I truly love fixing and building tools.
Often it is not so much about the end result, but the journey towards it; "the hunt is often better than the catch".
With all your skills, you can make very interesting deviation / side-steps before you get to your desired goal.
Perhaps, during your journey, you may encounter some crappy movements whereby your anvil and blacksmith hammer may come in very handy 😃
Love to hear about your endeavours 😉
Edited by Endeavor
5 hours ago, Stagesmith said:
My name is Ernie.
Hi Ernie and welcome.
Just been looking at your staking tool that you've made, very impressive 🙂
Seattle's an interesting place for hobbyists and watch repair. They actually have a school for hobbyists. We also have meetings for anyone that has a interest in watch repair. I'll give you the links below.
http://www.norwestschoolofhorology.com/
http://www.norwestschoolofhorology.com/wwca/index.html
    • Hello, I am just starting to learn how to hopefully service mechanical watchs Right now I started by acquiring a bunch of tools and a first practice movement (ST36).  Since I got it last week I have been practicing disassembling and reassembling it (I don't yet have the tools and products for washing and lubrication as I estimated that the first step is the manipulation required for assembly and disassembly). To be quite honest the result have been interesting.  My first step was breaking the setting lever screw when I was trying to remove the stem (OK practice movement won't be able to set time, oh well). I did manage to mostly disassemble the movement (I kept the balance together, didn't open the barrel and didn't remove any jewels). I messed up the balance spring a bit when removing the balance (I think the impulse jewel was still in the fork or something). There was  a small tangle. I reassembled everything and surprise the movement came back to life. I disassembled it again and decided I will try to fix the hairspring.  So with lots of trouble I removed it from the balance and when trying to fix it I made more of a mess.  After reinstalling everything the balance won't oscillate (likely the spring rubbing on things, either the plate or the cock). Right now I wait for my second st36 and continue practicing while slowly buying what I need to wash parts and lubricate them.   Any of you think there is a chance I can repair that spring or find a balance complete for that movement which will cost less than the whole movement?
    • Hello, I am a software engineer and all day spent in front of my computer makes me want to do something more manual as a hobby. I like the mix of intricacies and basic technology of mechanical watches, the fact that such marvel could be built manually hundred of years ago fascinates me.  So I decided to combine the two and learn "watchmaking"  (between quote as I don't expect to ever be able to make a watch). My first goal is to be able to service a mechanical watch. My current status is that I am pretty good at breaking small parts in watch movements
    • Nothing special to the horological world, but this is my travel watch. For whatever reason, this watch has accompanied me through airport security more often than my appendix and gall bladder. I feel as if i need this with me as much as my passport.
    • Apologies for digging up an old post but I am thinking about doing the same. Can I ask the OP what medium he used on the wheel. Was it a sanding disc and polish and if so what grades. Thanks.
