I'm back
I've never seen one quite like that, but I have seen plenty with horns on the escape wheel side, quite elaborate ones too.
One theory for this design is that it is to poise the pallet fork, i.e. equal mass on each side of the pivot, to help reduce positional variances. Whether or not that is the case I have no idea, although I can see the thinking behind it.
Yours though looks almost as though there is more mass on the escape wheel side with that great big hoop.
55 minutes ago, RichardHarris123 said:
Any ideas then
Marc and Nucejoe's reasoning to balance the fork seems sound. Although the split ring design seems oversize for that. Unusual design that could risk damaging the escape pivots when removing the escape lever 🤔
3 hours ago, RichardHarris123 said:
Hello all.
It's been a while but I'm back.  I've haven't been on for ages due to all sorts of boring a trivial things.
I have seen a pallet like this before, what do you think.  A cage? Around the escape.
So what is this in Rich ? Besides the lever design, the perlage and chamfered lever bridge is indicating something of quality.
More pictures tomorrow, unfortunately movement only. It was pin set.  No makers mark but serial numbers.  I think it was a quality watch.
Plenty to come, just got 50 watches for ££200 , all could be on the 404. Six fakes thrown in for free, very poor quality.  I've binned 4 of them already.
15 minutes ago, tomh207 said:
I remember seeing somewhere that a pallet fork with a ring that went over the escape wheel was an alternative mechanism to banking pins , could it be this?
Tom
That also crossed my mind Tom but then i ruled it out thinking that potential overbanking would damage the escape wheel pivots. Just seems an elaborate alternative to an already simple and robust design.
7 hours ago, RichardHarris123 said:
Hello all.
Thinking outside of the box, does it become useful outside of the watch.  An aid for adjustment of the pallet stones.  Probably just a watch folly, lets build it that way because we can and it looks cool and interesting .
Yes, no banking pins.20230206_182538.thumb.jpg.5a9fb3b21a45d64e765a7c9db4780ef1.jpg
🤔 I'm still not convinced, why would the maker risk knocking against the escape wheel ? Seems a good way to break a pivot.  It was actually my second thought though.
What about the sides of the mainplate where the lever sits, wouldnt this provide the banking.
On 2/5/2023 at 6:18 PM, oldhippy said:
The escape wheel is nothing like it for it to be a jurgensen escapement. What is the roller like on the balance?
Here is a photo of a jurgensen escapement.
5 hours ago, ColinC said:
I did start going down the rabbit hole of looking for a spare balance wheel / hairspring....  And while it would be nice to own and maybe even wear the watch I first learned on, I only bought the watch as something to learn on and it has done that job well.
I have also considered buying myself an ST36 along with a case, dial and hands (or I saw a complete watch on aliexpress with the same setup that was recommended was a good learning tool)
No banking pins anywhere, it must be instead off the pins. Wierd I know.
No need for banking pins. The pallet passes through the gap (red arrow)and it's the edges of the gap (green arrow) that provide the banking.banking.jpg.1c0be44da884325a8e91bfa7235af109.jpg
Agree with that marc, the banking therory for the extra lever construction doesn't seem to fit. I still think its just an elaborate design. John or nickelsilver i think is needed for some confirmation.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
    • could start a new sub-brand: Bergeon-Pro Worked for Apple phones! Ah they already beat me to it:
    • Hello, those RR pocket watches are nice watches, there are still parts around...
    • The hairspring looks to be in good condition from the photographs, it is natural that the balance will perform slightly differently in different orientations. Assuming there is no damage, the difference may be caused by the balance moving relative to the jewels, not the hairspring itself. So too much space between the jewels (endshake) and the difference will be greater, if one jewel is oiled and the other not, then again a lower amplitude in one position than the other....and so on. If the difference is reasonable (like your 13 seconds) the the best thing to do is to make one position slightly fast (+7 seconds, and the other position slow -7 seconds) then this averaging of the error will make for a more accurate watch in use. If the difference was much greater eg 100 seconds, then you would need to troubleshoot the problem. Additionally, you need to let the watch run-in for 24-48 hours after a service to allow the new oils to work their way in to all the jewels and pivots etc before you make a 'real' timegrapher test, otherwise you can get strange results. For example the oil in the top shock setting may be evenly spread, but not (yet) in the bottom setting = high difference.... after 24 hours this oil will probably have sorted itself out and the difference may be much better.
    • Oy! No bad words in our forum please.
