Introducing FireEng
FireEng
Hi all,
I am an engineer and I like all type of mechanism. I always liked watches.
I loved the history of the raketa watches, so I bought a cheap one on ebay. I would like to restore it, just for the experience.
I want to start with some aesthetic repairments. The case is scratched, and the dial seems to be dirty. Unfortunately I didn't find book in italian (which is my language) that can help in these repairments. I hope that I can find some help here in this forum.
Thanks
Like you, I have found Raketa watches to be well made and enjoyable to service.
The trouble is that during the Soviet era, most of the cases and dials were made from very cheap materials, espcially for the watches meant for the domestic market. There are exceptions, but this is mostly true. So, they don't age well.
This may not help you, but I would advise you to concentrate on servicing the movements and helping them operate correctly, and not worry much about the dials and cases. You might get lucky and find new and good cases that will fit your movements, but I wouldn't count on this. I enjoy wearing some battered looking watches, they all keep reasonably accurate time, and they were not very expensive.
This is the watch. As you can see the back of the case is really scratched. I cannot understand if it is brass or steel.
I would like to polish the case and to clean the dial, just to start. Are there any references about these procedures in the group or in some book?
I also don't know if this model has a name.
Edited by FireEng
Hi have a look under the balance wheel, Ican see a logo (makers mark) and there should be a number in your case 2609Ha which is the calibre. There are parts sheets for these watches.  It looks in fair condition and would respond to a good service and clean up. The case looks pitted due to the acidic sweat reacting withe the metal. There are a few vids on U Tube if you search for them. All in all a nice piece of Russian tech.    Cheers
Hi there are quite a lot in the vids it’s just a case of searching, try watch case restoration as a search string.  The case it’s self is a bit tatty but to be expected if it’s been worn for a long time but could be improved some what by just brushing with a brass brush. Nothing too vigorous just to improve the look. If you search Cousins uk document downloads you will be able to find a sheet for the 2609.  Cheers
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.   I have to make a crank handle for my Joe Collins spring winder as well and some spring retaining tubes as I can't find where I can buy them. I will be salvaging (here I go again) the aluminium tubing from my old hang glider which I have to scrap as I can't fly anymore and it is too old to sell. All the aluminium tubing is aircraft grade so I am hoping it will be suitable for the winder. I have also been making a bushing tool and I have just worked out that it will work well with my Dremel stand. So another thing that I can turn into a working tool. Don't know if you guys have ever seen the ad about the guy that buys himself a new 4WD and the son says "We're going to need a bigger boat." So Liz is looking at all the stuff we have to get rid of and says "We're going to need a bigger bin." Really difficult to work out how big a Dempster bin we need. Sigh.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
