Mainspring
Clockwatching247
You need to remove the pin that I can see red circle, there might be another on the opposite side. Then push the whole thing out. You should see screws that you need to unscrew, the drum will come away which will leave you with the dial and movement.  You will need to remove the hands then you can remove the movement, some movements will be held by pins some are held in place by folded or twisted tabs.
The spring by its looks doesn't have much power on it. With the movement free you should be able to see the click and its spring, put the key on and hold the key as if you are going to wind it and with a screwdriver move the click away from the ratchet and let the spring down. From what I see you have parts that are not in place these are the cup screw that holds the balance and it also holds the regulator which is on the movement.
Edited by oldhippy
ive had one like this,
you need to use a drift to tap the drum out, some are so tight its a joke, the 3 screws you have i believe are there to hold the movement onto the drum, you will be able to access them once the drum is removed.
My advise would be to mark the drum and the case so you put it back in the same orientation as it cam out due to the tightness of removal
Hi sometimes with these barrel/drum clocks the whole drum has to be removed and as transporter said they have to be drifted out carefully. After removing the fixing pin in the case side , mark the position of the drum and then use a wood drift to push out the drum. It could be corrosion between the wood and the brass liner/drum that’s holding it. When out you can gain access to the movement screws around the bezel and remove the drum sleeve from the clock, you will then see how to let down the main spring
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
