1956 Bulova 10BPAC 23 jewels service
This guy (Minimachining) has a playlist of him setting up and using various attachments on his Sherline lathe. Â I know nothing about CNC machines but had a question about making screws. Watchguy.uk has a section on his website where it allows you to enter parameters for screws and wheels and then 'generate code'. Is it as simple as that sounds, can you 'tell' the CNC machine to cut you a screw (or stem) by giving it the code for a particular screw or stem and it happily makes one for you?
Thank you all for the advice, but as the prospect of salvage was slim,I sourced another complete donor balance and all is well. Â
The date wheel is supposed to have a small spring that moves out and pushes the date wheel. It is a known point of failure.. Does yours have it? See picture below: Â
