Hello there from the Netherlands
Wich
Hello,
I've recently gotten into the hobby of watch maintenance and repair. After watching various youtube videos on watches over the past year or so and having gotten Mark's excellent watch repair courses I've taken the plunge and dove into my first movements. To follow the course I've obtained a couple of Chinese 6497 clones to practice on as well as a skeleton version which I cased up without any dial giving to me a neat effect which I'm currently wearing as a daily watch. I've disassembled, cleaned, reassembled and lubricated the 6497 movements a few times as practice.
The plan is to get some lot or lots of non-runners from the usual sources and try and get some of them in working order. I also received a non-runner from my brother that he asked me to get running again. It is a fairly odd thing with some mechanical bits and bobs next to a quartz movement, which is a whole story on it's own that I'll ask about in another thread. My father also gave me my grandfather's old Remova watch bought in 1964 which has lain in a drawer for way too long, but given it's history I won't get into that one until I've had some more practice on some junkers.
Looking forward to learn and in future hopefully contribute.
Regards, wich
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
