How to remove pressed on wheel? Specific tool?
Titanium rods are available from AliExpress. Titanium is not some super material as one might think. It cuts like aluminium. I used quite a bit of titanium in dentistry.
The problem with titanium is that it fatigues easily and cracks. Anyone who has used titanium tweezers will understand.
1 hour ago, mikepilk said:
But where would I get titanium rod ?  Can you file it ?
Ebay sells it. I shaped my titanium tweezers, so i dont see why not. It comes in different grades, the higher the grade no. the less titanium content it has and is harder.
Compared to steel its not particularly tough, but it does have the highest strength to weight ratio. I like it for tweezers because it doesn't scratch  but it tougher than brass, the cheap brass tweezers anyway. So i imagine titanium rods are going to be stronger than brass rods.
Edited by Neverenoughwatches
6 hours ago, nickelsilver said:
WIth the Bergeon 6016, you slide it under the wheel, then twist the handle, and the two blades tilt, effectively rising in height, bringing the wheel with it. I have one, and never seem to find a wheel the blades actually fit under. I use the Presto tool. Those work great,
Personally I find you need both tools because there are situations where one may not work. Then there is the other problem which I did point out that apparently no one was paying attention to.
3 hours ago, LittleWatchShop said:
My Dad had one. Somebody on this forum called a pivot breaker several years ago.
One of the classic problems with any tool is if you don't know what it is you will break things. Look how much destruction occurs every day with newbies and tweezers and screwdrivers a perfect example of destruction of watches because They don't know what they're doing but we will blame the tools not the individual because that's what we do. So basically the tool is bad the use of it is not especially when the use of the tool may not be obvious to some people
oh and there is the other little problem what exactly does your father have? Oh yes the picture let's look at the picture
Nobody was paying attention to the fine prints because I did point out something let's look at my tool because as I pointed out the quantity of tools that we can purchase seems to have decreased? I wonder what that means when let's look at mine and technically I had the third one but one of the problems With working in A shop with other individuals is if they like your tool it may go missing. So when I left the shop I was unaware of a missing tool or two or three. This is actually a current problem where I work now I can't Lock my bench that I never know if I'll even have my tweezers when I get to work.
There appear to be two of them? Now we need the physical catalog because it has stuff that used to exist that no longer does
When the problems today of course is you only get one tool and as an added bonus you get a really poor description because it gives you a size that I have no idea what it means because their size references do not compare above you get what is probably the tip size or maybe it's the thickness size on twisted I'd have to measure it and now you get this size that means I have no idea what.
Edited by JohnR725
Sorry John, I'll go and stand in the corner 🥴
I did once buy a cheap Presto tool and try to file the end to make a 5 spoke wheel remover. The metal was such poor quality it didn't work.
10 minutes ago, JohnR725 said:
The 1.2mm is the thickest bit. The tips are about 0.1mm
id anyone notice he used an incorrectly sized screwdriver on the crown and ratchet wheels?  He also seemed content with what I thought was a reasonablely high beat error.
Are you questioning somebody on a YouTube channel how dare you. YouTube personalities are God's we must never ever questioned them. There is quite a few of the watch repair channels that even though as I said these people are gods and I must worship the ground they walk on I think there false gods with an attitude and even though they have a YouTube channel with a whole bunch of followers maybe you should usable common sense like Uber observing here and maybe they really aren't God's maybe there false gods.
Oh and timing machine results? One of my amusements was people selling watches on eBay and they will happily show you the timing machine results and claim the watch was serviced but well I guess their learning and you're going to buy watch and the learning phase because a lot of times the timing machine results suck and I wonder why you're proudly showing your handiwork? On the other hand the probably making money selling these watches on eBay. Although I have seen some legitimate people selling watches where if the watches running to put her on timing machine the show you this is the state of the watch are buying we haven't service did yes it's running but it runs like this. In other words it's running really poorly and there showing you as opposed to look at my handiwork. Which of course brings up the problems you buy something on eBay that was serviced and looks like crap on the timing machine now you'll have to deal with it
Oh I wouldn't worry about this this is a minor issue. If you want to do something bad go against the narrative of a tool blessed by every God in the known universe like I did then you get your story squashed and embarrassed but don't worry it was done for the greater good of the group.
The reality is we can't pay attention to everything is why like group discussions where one person will see something that you don't see and you'll see something different and together as a group we will hopefully see the big picture hopefully.
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
