Computer Crash
Hi Guys. Watchweasol here my contributions will be a little slow now as my main lap top crashed. Power supply problem. Problem is a lot of my Data was on the machine although I have. Some on sticks and another machine.  I will still be on line and will be back full steam when I get another machine.     Cheers
  • Sad 2
If your problem is with the power suply and not with the hard disk then you can easily recover all your data. There are USB to SATA converters that work just fine to use your disk on your new computer as an external disk and you'll find all your data there.
Then you can use your HDD as a backup media.
i.e.: https://www.amazon.com/s?k=usb+to+sata+box&crid=3I1IEQ4ANU2XI&sprefix=usb+to+sata+box%2Caps%2C218&ref=nb_sb_noss_2
Edited by aac58
probably less of a problem today but if you're dealing with mixed computers old computers etc. something like this is nice because you can plug just about anything into it
https://www.amazon.com/AGPtek-Drive-Adapter-Converter-External/dp/B00BIE996S
as it's a laptop typically with limited or one hard drive you should think about a external hard drive to back up everything to. Because as you're well aware maintaining a huge collection of horological data can eat up a lot of space and is not good to have it on one hard drive only.
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
