cortman Posted November 11, 2022 Share Posted November 11, 2022 Hi all, As the subject states I am suspicious of this ETA 2836 movement. It's from a very clean Eternamatic 1000 5 star that came in with a winding/setting issue (upon examination the the stem turned out to actually be twisted). Other than the fact that these vintage Eternas are often frankened or outright faked, two things make me suspicious of this: First, no ETA stamp on the mainplate under the balance, and second an odd ridge of mainplate where it should, I believe, be cut out for the keyless works. I've attached some closeups of the areas in question, and a general shot of the movement as well. I'd love to hear from you all who have seen many more of these than me! Thank you very much. Quote Link to comment Share on other sites More sharing options...
Nucejoe Posted November 11, 2022 Share Posted November 11, 2022 I have two eta2836 out of Oris made in Hong kong which are so poorly the polished, gears and all, I think of it as a sub Swiss standards. if you have worked on a Swiss or good grade Asian made piece, you know if yours is the Hong Kong junk. The quality of Asian made ones are slightly inferior to Swiss, not too bad, and power some fake pieces so fake doesn't mean poorest quality. Rgds Quote Link to comment Share on other sites More sharing options...
GuyMontag Posted November 11, 2022 Share Posted November 11, 2022 I only have one 2836 and it doesn't have the ETA stamped either, just the movement number. Quote Link to comment Share on other sites More sharing options...
Nucejoe Posted November 11, 2022 Share Posted November 11, 2022 @GuyMontag your watch is a high grade, adjusted in six positions and etachron, rotor bearing looks better built too. Older eta versions had no etachron, which doesn't indicate fakeness either. I believe Cortman's is no fake either. Quote Link to comment Share on other sites More sharing options...
cortman Posted November 12, 2022 Author Share Posted November 12, 2022 Thank you very much @Nucejoeand @GuyMontag! I believe you are correct. I appreciate the insight! Quote Link to comment Share on other sites More sharing options...
