Hi all,
I need the help of this wonderful community. I have serviced a 7009 Seiko movement and I have a problem I am having a hard time understanding. Hope someone can steer me in the right direction. After I set the time the watch runs great with high amplitude and 0 beat error as measured on a timegrapher for 20 seconds or so after which the performance starts degrading until eventually the watch stops completely. If I move the hands (as in reset the time) a few turns the movement starts running again with good performance and then degrades again to a complete stop.
I am not sure where to look for the problem. Any help will be greatly appreciated.
Best,
Ronen
Thank you Nicklesilver and watchweasol.
The amplitude and rate go down after coming to a complete stop after 3-4 minutes.
I will try this today and post back the results.
Edited by Ronenash
always nice to give us the actual numbers like what exactly is a high amplitude especially were discussing a Seiko and nice to give us a picture. Also nice when you're putting it on the timing machine to time more than one position bike may be crowned down it would be nice for instance a minimum of two ideally I like more but will go with two
then this isn't a timing issue. does it do this gradually or is it doesn't do it suddenly? I agree with the others there's definitely a mechanical issue somewhere else it has probably very little to do with the balance wheel if you come to a told.. If you remove the balance wheel and push on the pallet fork is there any power at all there when the watches come to a stop?
OK, so I found the source of the problem but cannot figure out the reason. As soon as I install the day finger and tighten the screw the movement starts loose amplitude until it eventually halts.
Normal amplitude is between 250 and 260 degrees very consistent with the movement in the face up position and as mentioned above, as soon as the day finger is installed it starts to loose amplitude. I will leave it overnight to run with the day finger removed to confirm this for sure. I have also included the schematic for the 7009 maybe someone will get an idea.
Thanks for all the help thus far.
7009A.pdf
I see others have beaten me to the answer but I'm going to stated anyway. It's amazing what will happen to a running watch if the wrong screw is in the wrong place. I had a vintage 18 size full plate American pocket watch which means limited visibility. One of the screws on the dial side was in the wrong place and hit the spoke of the third wheel. So yes it's amazing of the screws sticks too far down and touches something it shouldn't the watch will come to a stop if you're lucky. Worst-case but I'm the skip over how I know this one the wrong screw you could end up breaking something. But seeing as how your watch runs with the screw out you haven't broken anything you just need to evaluate whether you have the right screw or not.
Thank you all for the super valuable help. I have finally figured it out this morning. There was a microscopic string of fiber between the wheel and the finger which cause friction when the screw was tightened.
I have now completed my first full service for a Seiko 5 gifted to me by my father when I graduated high school. Brought new life to this almost 40 years old watch. I am super happy for being able to complete this project.
Now to my next project, a Hamilton 992b.
Ronen
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
