Hello everyone,
today's problem is too much side play on my Boley & Leinen  8mm. lathe. The end play is of course adjustable but how does one go about reducing the side play on cone bearings, is lapping advisable ?  Any thoughts, hints or advice will be greatly appreciated.
Cheers, Mike
I don't understand what you mean by side play. With conical brass bushings, when the end play is adjusted correctly, there shouldn't be any side shake.
Do you mean that the spindle can rattle around in the headstock? Or is there a waggle of the round bar in the collet?
What kind of collet are you using? Have you tried another collet or chuck?
Hi, this lathe has hardened steel conical bushings and even with the adjusting nut tightened up so there is free  rotational movement of the spindle but no end shake, the spindle can still be moved axially by a small amount. At the moment I am using a three jaw chuck.
Hmm... Sounds like a very well worn lathe or the front bushing has drifted. You could try putting a washer under the locking ring to apply more pressure on the back bush. I adjust the amount of play on my lathes by tightening the ring until the spindle locks up , then back it off until the spindle can turn again.
It would take many thousands of hours of abusive use to wear the cone bearings to the point that they had radial play with the bearings snugged up to zero axial play. For the spindle to turn there has to be some play, let's say it's adjusted to a bare minumum to allow oil to flow, like 0.005mm: if checking something like a 3 jaw chuck that will be perceptible. If using an indicator to measure it might seem like a lot; but in use, the oil creates a hydrodynamic film that is very rigid.
You have one of the highest quality lathes ever made- I would be curious to see what the bearings look like. For them to be worn they will look horrible. But bottom line, there is only one adjustment, the adjusting nut at the rear of the spindle. The cone bearings (which have two conical bearing surfaces each) should adjust both radial and axial play simultaneously.
Or just one episode of severe abuse, like bashing the spindle in the wrong direction to remove the spindle.
Hmm... On further thought, bashing it in the wrong direction would actually close the distance between the bushings and make it tighter.
Not suggesting that you bash your spindle in. 🤣
Hello, dismantling the headstock to take some photos I discovered the cause of the problem....it was hardly noticeable. Under magnification I noticed that the locating pin for the collet (in this case, the 3 jaw chuck) was slightly proud of the spindle. A smart tap with a fine punch (and with a collet inserted in the spindle)  and the pin moved below the surface. After a quick clean, lubrication, rebuild and test run the lateral runout is acceptable.......problem solved 😅.
Thanks again to HectorLooi and Nickelsilver for their interest and suggestions.
Mike
I had this problem with my first lathe. Some collets have a shorter cutout and when tightened fully, it will push the index pin out.
Check your collets for any with short cutout grooves. I had to use a grinding disk to cut the slots longer on a few of my collets.
    • It's from Rolex spare parts catalogue published around 1940-1950. They are quite expensive and hard to find one. For future reference you can use https://thewatchmakersapp.com - at the moment that app has the most reliable and complete Rolex movements calibers listing available (around 100 and adding more) including all vintage movements from this catalogue (with scanned technical sheets linked), some of that info is not available anywhere else.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
