first time buyer long time lurker
ryan162
Mechanical watches....Who doesn't admire a machine so very well designed and manufactured? A promotion at work resulted in scratching a long felt itch for owning a nice watch. Some small research later I understood anything I would buy would most likely require a costly service and, more importantly, the service was something I should be able to accomplish on my own. Any chance to buy tools instead of a service is always rewarding. I'm gearing up to service a tired 1943 Bulova Ord watch that's running quite well already so that brings me here. Thank you to all those who have posted on this. There is a large knowledge base I hope to learn from and add to.
Thank you for the welcomes! There is a extreme amount of grime built up on those jewels it seems. I have not tried to remove it yet because I'm still waiting on lubricants before I take this apart. The big assumption I have is some heavy oil/grease was gooped there decades ago and dried up, so I hope that appearance isn't a indicator of devastation below. It will be a fun adventure for sure.
The jewels look fine. It looks like someone has wiped the movement with Rodico (or BluTac ?) and some has remained on the jewels. What ever was used it was very dirty - look at the smears on the bridges.
Apart from all the dirt, it looks to be in good condition. Good luck with the service.
Thank you for the replies. I hadn't considered a clay of some sort but zooming in further sure does look like it. Yikes...I hope someone didn't pay good money for that job. Of course it is running 80 years later so I guess things could have been worse for it.
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
