Pdf Of Practical Watch Repairs
I think it's best not to potentially get us in trouble with the copyright owner so I have removed it. But thank you anyway - i know you were just being helpful. :)
HI Mark i wasnt sure if it was still under copy sorry if i did wrong
I believe it is still under copyright :)
I am no expert but I understand that copyright in the UK is for the lifetime of the author plus 70 years. Someone correct me if I am wrong.
[emoji106]
"Duration of copyright
The 1988 Copyright, Designs and Patents Act states the duration of copyright as;
For literary, dramatic, musical or artistic works
70 years from the end of the calendar year in which the last remaining author of the work dies.
If the author is unknown, copyright will last for 70 years from end of the calendar year in which the work was created, although if it is made available to the public during that time, (by publication, authorised performance, broadcast, exhibition, etc.), then the duration will be 70 years from the end of the year that the work was first made available."
  • 4 weeks later...
hey guys! i am new here,and really dont have much to contribute,yet i am very interested in this subject and hope you dont mind my sitting in the corner(so to speak) and learning !?
Welcome aboard Irish. There are a lot of good people on here willing to help out when they can. It doesn't matter whether you just want to tinker, or get into the serious side of watch repair, as long as you enjoy what you are doing. I'll go and clean out the corner to make it more comfortable for you! :)
    • Now thats a real man's tool press 👍. I have one just like it in my back garden for when just CANT fix a watch . Its not something i have had to do yet, @Waggybut wouldn't any type of press be able to do this ? What about an adapted chain link  extractor work or a micrometer with some sleeve pushers made to slot over the ends. @Waggy Found something that could work Scott, comes with different size pins and pushers. Only bit that would need making is a round former to support the inside of the case, a piece of stout timber, bit of oak or mdf might do it. What i like about this one is the pin is pushed in, its in a sliding sleeve so it doesn't turn while its being driven. This has 4 pin sizes and 3 stumps as well so it will come in for other applications, the pins could be adapted to take other accessories from jewelling tools. I've just ordered one myself for some play time.
    • So I purchased this one based on my case number being listed. (Unless my case number is incorrect. The last digits are faint)
    • I have the same tool from AliExpress and get the same anxiety when when using it. But you have to admit it looks awesome on your tool shelf. Makes you look like a pro. 🤣 Looking at the photo of the Horotec tool, it looks equally flimsy. It probably comes from the same factory. I was thinking of using the pushers supplied with the tool and making a hand tool from a cranked jeweller's punch. I'll grind off the tip of the punch and drill a hole at the end to fit the pusher in. The cranked shank would be able to clear the watch case give a straight in-line axis to exert force to tap the pendant tube out. Should be robust enough to last several lifetimes. I wonder why nobody makes it. 🤔
    • It reminds me of Ukrainian eBay sellers of Russian watches. More often than not the listings include the phrase "Serviced by Master Watchmaker". Of course, they never are, and it should be expected. It's the most corrupt country in Europe, definitely on par with Russia. Today our tiny country (Sweden) sent them another $1 232 255 518 with no accountability whatsoever for how the money will be used.
    • Now that is taking it a bit far. You are going to need a bloody big workshop.
