Hello!
I'm new to this watchmaking and so far I have successfully taken watch apart and lost pieces.
I have a K.F 260 movement and got a mainspring from eBay for it. I did obviously unwind it by accident while trying to figure out if I put it the right way or not.
I realised that this will cost a lot in mainsprings and maybe a mainspring winder would be a good purchase. I'm just not ready to buy the whole Bergeon winder pack and while checking cousinsuk I realised I could just buy the parts as I go and need it.
But some questions remain and I'm not sure to get I understand it correctly:
1) Do I need to have the "right handle" to use "right winders"?
2) Are the right and left handle for "right and left" handed people or are does that direction actually matter to wind a mainspring?
3) The size of the winders defines the size of the barrel, for example "Right Hand, Ø13.00mm (No.9) Winder" would wind a mainspring to fit in a 13mm barrel. Is this correct?
4) I see that I can get a "Right Hand, Ø13.00mm (No.9) Winder" and "Right Hand, Ø13.00mm (No.9) Arbor". It seems to me that an arbor of 13mm is way too big. I'm assuming this is to replace the axis that grabs the mainspring and winds it (in case it breaks or gets used". Is this correct?
5) I have 2 mainspring to wind into one 16mm and one 17mm barrel. I'm wondering if I could get away with only one 15mm winder. It lookalike there is enough space to wind those mainsprings. Am I correct?
Thank you to whom could shed some light here.
Hi@watchweasol
I tried that before hand - actually I tried to research that on multiple forums but I can't get a precise answer for those precise questions :)
For question 1 and 2 there is contradicting answers. For questions 3 and 4 I don't find any clear answer and for 5 there is some sort of positive answer but then there is people saying that "it is correct but" we shouldn't.
I'm a bit lost with that tool.
Hi Daniel  sounds like its a bit confusing what with everyone having a differe.nt opinion.  My self I fit the springs by hand and have done so for many years. So as far as having an opinion on the winders I shall have to leave that to the persons who use them,  I know the Bergeon one uses a red dot on the handle for one type and a blue dot for the other, not much help.         all the best
You do not need any handle. You can grab the winder without the handle.
If you turn the crank right (clockwise) the right handle will lock safely to the winder the left handle will not.
Edited by Kalanag
Just for clarity, there are the arbors (right and left), the drums (universal) and the handles (right and left).
1- The handles are specific for right or left hand wind springs. As Kalang said, you don't need the handle; it's easy enough to just hold the drum (I can't remember when I used the handle).
2- See 1
3- The dimensions given are the outside diameter of the drum of the winder. So a 13mm would fit inside a barrel with an internal diameter of 13+ mm.
4- The arbor is specific to its drum , with some exceptions. If you check this link, you will see all the Bergeon winders listed by number, also with drum diameter and arbor diameter. For a #9 winder, with 13mm drum, the arbor measures 4mm diameter. It happens that the #10 winder uses the same size arbor. Looking at that list, I see there are 8 different arbor diameters, for 19 different drum diameters. Yes, the arbor is performing the function of the barrel arbor when using the winder.
5- It depends. Sometimes you can go quite a bit smaller than the measured internal barrel diameter with the winder, but it isn't a hard rule. Remember that since the drum needs to fit inside the barrel, after accounting for the wall thickness of the drum the actual space to wind in the spring becomes significantly smaller than the normal space the spring should fit into even for a drum that is close in size to the internal diameter of the barrel.
Edited by nickelsilver
Sorry, I was not clear. I meant it appears, for example, that on the question "Are the right/left handle to be coupled with right/left winder" there is a bit of disagreement. Of course, each person has its own habits and tool choices are totally
@nickelsilver@KalanagThank you for that clear answer. I was under the impression I would need the handle. I'm going to skip them then.
@nickelsilverSo if I get it correctly, I could use a handle that has the "plate part" bigger than the drum? Because I use the arbor #12 (4.5mm diameter and 16mm "plate part") it will fit with the # 11 (4.5mm diameter and 15mm "plate part")
@nickelsilver If I get it right, the size that Bergeon shows (#12, 16mm) this fits in a barrel that has an inside diameter of 16mm? On top of that, could I get the right drum #10 and then only purchase the left arbor #10 as the arbor is quite cheaper?
I'm assuming that for my pocket watches, when we have barrels that are 17.4mm and 15.6 there is more room than on those smaller sizes.
Thank you so much for all that clarity!
Edited by DanielGato
Yes, as long as the cover (plate part) covers the drum you're fine. I also often use smaller arbors in larger winder, as long as the cover is large enough, as many springs have an inner curve a bit too small for a given drum size. The "slop" in size difference of the arbor isn't (usually) an issue.
If you have a drum that measures 16mm- and my #12 does measure exactly that- it will have a hard time fitting in a barrel with an internal diameter of exactly 16mm. 16.10mm no problem; exactly 16mm it may bind in the barrel.
There is a bit more leeway when substituting larger sizes, yes, but only to a point. Trial and error will tell you how far you can go undersize with the winder.
Thank you so much for those precisions.
while looking at videos and reading online it made me think I needed the whole 1000$ Bergeon.
But now with your answers I can get away for 120$ and be able to use on my 5 pocket watches / watches. It is cheaper than those Chinese winder packs.
I'll get a new drum as I get a new watch. That should dilute my spendings over time.
Thank you again!!
Another thing- if you keep the little rings the springs come in you can pretty much avoid needing the left hand arbors- just wind up the spring normally  and insert into the ring, now you can install it in the barrel whichever way is needed.
2 hours ago, DanielGato said:
…But now with your answers I can get away for 120$ and be able to use on my 5 pocket watches / watches. It is cheaper than those Chinese winder packs...
CousinsUK sells single winders from these Chinese sets for £16,60 plus tax. I am happy with these items. The hooks are from steel meanwhile!
Mainspring Winder
@KalanagI watched a very long video on YouTube where they reviewed that kind of set and the take away was that the hook on the arbor would break very easily - specially for beginners that have no idea what they are doing. I will give it a try.
@nickelsilverClever tip, I'll try it.
Thank you for all this information 🙂
As I said this flaw (hooks from brass) is history!  🙂
EDIT: It is still brass as a magnet and my microscope told me! Sorry for my missleading information! 😦
But I‘m sure as a hobbyist you won’t use this winder frequently enough to wear the hook down.
Edited by Kalanag
  • 6 months later...
Hi,
Found this thread while researching mainspring winders. Just broke my second mainspring and feel that i need to start using winders instead!
I was intersted in these winders you mentioned, but since they are sold as movement specific how do you know which one to use? I service mostly watches from 50s - 90s. Trial and error if you have a few winders? Or did you reseach all the mentioned movements tech sheets to find their actual sizes?
Basically which 3-4 would fit most needs? As i have read that Bergeon 5,6 and 7 would be ok for most services.
Best rgrds
On 3/13/2023 at 10:43 AM, Kalanag said:
Thanks ! Interesting data! But it lead me directly further down the rabbit hole...
For example:
If I buy the Cousins version, and need to do a 11mm barrel, I would then choose the ETA2824 winder (?). This one has an arbor of 2,4mm . However the closest Bergeon, nr 7, has an arbor of 3,5mm.
So which would be better for general use in semi vintage (automatic) watches? I've seen most say that the Bergeon 5,6,7 would work fo most watches. But none of these have below 3mm arbors. Whereas the Cousins set contains no arbor above 3mm.
So how do I go about this? Are the arbor sizes sensitive alot of the time?
Buy the Bergoen ones for alot more ££, including the nr 4 size, and use it's arbor in one of the larger barrels (if thats possible) when needed?
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
