Now that I finally have my lathe and collets up and running, one of the next steps for me is making screws.  I have everything I need, except for a way of making the slot.  This means I need to invest in a screwhead slotting file, but the darn things are really expensive and I want to make sure I'm getting the right file for the job I want to start with.
I'm going to attempt to make a crown wheel screw. It has a ~1.5mm head, and about a .2mm slot. Relatively large, which is why I'm starting with this.
I *think* I want a Vallorbe LP1840 cut 4,  but I'm not sure. the 1840 has a tang, there is also the 1850 which doesn't.  The 1840 goes to cut 4, and the 1850 goes to cut 8.
I have the Vallorbe catalog, but I still haven't figured out for sure what I need in terms of the cuts, which also determines the thickness of the file.
Cut 4 is 0.55mm
Cut 5 is 0.5 mm
Cut 6 is 0.45mm
Cut 8 is 0.35mm
Help?
I don't think anyone makes them except Vallorbe now, and pretty sure the 0.35 is the thinnest still made. That's still a bit wide for most wristwatch screws; 0.20 is pretty normal. But it should still be ok (the 0.35).
I have 2-3 dozen I've bought second hand over the years, always searching for and coveting the thinnest ones. They are often chipped here and there but even chipped ones usually have enough undamaged surface to be useful. With or without tang isn't an issue, probably 99% of mine don't have it.
Some only cut on the edge and have pretty parallel sides, some are more wedge shaped and cut on the sides as well.
When making a screw I will hold the screw to be slotted either in a tiny vice (Horia) with a v-slot in the jaws that holds well without deforming the threads, or sometimes in a bench block if the screw fits closely in a hole, or if feeling fancy in a little collet holding tool (good for very small screws), and do the slotting under microscope. It's very easy then to center the file, take a couple strokes, if it's slightly off correct and then file away.
Thanks!
I can't find the cut 8 Vallorbe, but I did find cut 8 Grobet. These have a kind of diamond cross section, and will cut a tapered slot.  Smooth on the width, so I could use it on a rest, but I like your idea of freehanding it under my scope.  Practice, practice, practice 🙂
I think you've given me enough info to move forward, I'm really glad I asked before buying the cut 4!
Thanks again
(a little bit later)
Heh. Found an interesting suggestion in Fried's Bench Practices for Watch Repairers.
His idea is to take a single edge razor blade, set the edge on a cut 4 needle file, and then give it a good whack with a hammer. He says this will form teeth in the edge of the razor, good enough to file a screw of "moderate temper".
I check a blade, it's 0.2mm wide. Perfect.  I also have some cut 4 needle files.
I've got to try this!
Edited by dadistic
Well, I have my Grobet cut 8 file, and have made something that almost looks like screw.
Any tips on how to hold such a small file? After fumbling around, I settled on holding it between thumb and forefinger of each hand, and sliding it left to right while keeping some tension on it. The thing is floppy!
I also had trouble getting the slot started on center, the first strokes were wandering all over the place.
Ah well, back to making some more test articles to mangle 🙂
I really hope you wear safety glasses during this.  Razor blades can be very brittle!
Left handed?
I have found if you start your cut (guiding off your thumb nail) on the edge (on about a 45° angle) moving to a more parallel attitude as your cut gets deeper and longer.  This gives you the opportunity to adjust for center without scratching across the whole surface while also staying within your kerf.
Also, just for people who may not have a lot of experience with metal working, files really only cut it direction.  One of the fastest ways to dull a file is to apply downward force on the back stroke.  It would be a shame to obtain something so unique and ruin it unintentionally.
Have fun and a good day.
Shane
Yes, I'm aware that the file cuts in only one direction, but I do have a bit of a problem controlling down force on something so small. I hope I get it figured out before I trash the file 🙂
Should have said right to left as that would be the cutting direction, but what I was trying to say is that I was moving the file parallel to my body rather than perpendicular as one would with larger files.
I'll try your idea of using my thumbnail as a guide, thanks!
I was not necessarily speaking to you, just a tip for those who may need it.  I have seen some things that would make my shop teachers roll in their graves.
As to your filing, I find that I have more control making straight lines pushing away from myself (at a slight angle so I can still see the tool, as well as the work).  Moving perpendicular to your body may give you a tendency to pivot around your own center, causing you to make curved lines and cause difficulty controlling the downward pressure.
Let us know how you make out.
Shane
The file is too flimsy to push, it bends. Tension helps, and I'm just moving my fingers,  hands are still and braced on the workbench.
Cheers!
Edited by dadistic
On 8/13/2022 at 5:21 PM, dadistic said:
Thanks!
Thanks again
I am a little late to the party, but saw this and thought I would comment.  I am no expert, but I never give up.  Here is a screw I made a couple of days ago.  I used a Valorbe 8 to cut the slot.  As you say, it is really hard to cross center.  On this screw, I first tried to score a track with one swipe...I cant remember, but I did the return and not the forward cut to do this.  I did it several times until I had a track to ride in.  If I did it again today, I would probably screw it up (pardon the pun).  At the end of the day, I think it is something you learn by feel over time.  I am not there yet but moving in the right direction.
You can see that I did not hit dead center on this screw...maybe the next one, no??
BTW, I bought the file from Esslinger.
Edited by LittleWatchShop
Missed it by thaaat much.  *
Looks good to me, though. I made five little unthreaded test screws that I'm going to use for practice, I'm hoping that I can get it figured out after doing a few.
Then it's back to trying to make my screw plate work, I've already broken off a screw in the number 7 hole and had to buy some little carbide pc drills to use to get the stub out. Good thing those things are cheap, I broke one right off the bat 🙂
After that, it's heat treat time! Not going to try and make the first ones pretty, I'll just be tickled to death if I can get one that is actually functional.
Cheers!
* Apologies to Don Adams, AKA Maxwell Smart
Left handed?
Shane
Good advice that applies to any general hand sawing action, start the cut guided and angled up then level off .A look at the teeth will indicate sawing direction but most toothed tools will only cut one way, and that can be forwards or backwards depending on your preference. A thin blade should be drawn backwards with the teeth cut facing toward you or it will buckle. And as shane has said a pressured pull stroke if cutting forwards will soon deaden the tooth's sharp cutting edge. As a fact the Western world saw on the push stroke whereas the likes of Japan etc. Cut on the pull stroke. I have a few Japanese saws that are ridiculously sharp, the pull stroke takes a little getting used to after 40 years of pushing.
Cheers!
A little trick here. Screws the screws flush into the end of a wooden dowel say 6mm then the dowel into a vice. Then you will have more diameter to work on which will create a guide for the saw file. 🙂
Edited by Neverenoughwatches
Just noticed a slight unmentioned point lol.  When i said screw the screw into a wooden dowel, this is best done with a pilot hole in the dowel then a pin vice and then tap the screws home. But I'm  sure you would have figured that out. Screwing them out would be possibe 😅
    • Welcome to the WRT forum.   Both pieces are worth TLC, they don't make them like these anymore, so you are looking at a limited available quantity. I suggest working on them when you have acquired good dexterity and experience.  Chinese keep making same chunk= junk and  love to see you break them, so to sell you another one, the fact that  they don't sell spare parts supports the point of my arguement.   If you are buying now, why not buy two Swiss scraps of the SAME CALIBER in need of repair, such that a good running one can be made out of the two, plus,  you will have your own spare parts inventory, well sorta. Keep us posted when choosing scraps  and ask questions, no $  charge for advice.  No shortage of help and advice here, we'll work with you till your rebuild one ticks happy and accurate. Regs
    • Hello welcome to the forum.   I have added a couple of documents you may find worth reading TZIllustratedGlossary.pdf TM 9-1575.pdf
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
