Well it happened!!! That's what I get for not taking my time.
the hardware works fine, but I need to work on my side of the equation, have squashed a few cannon pinions trying to find that 'Goldilocks' zone between too much force and not enough.
My Horia clone is 4/4mm, I have seen 3/4mm on Ali but the 4/4mm is the more useful imo Tom
The Horia clones seem to have 3mm pushers and 4mm stumps - at least the ones I’m looking at have that listed in the specs. But who knows, perhaps there are various iterations and most don’t list their specs. I can’t find the specs for the 31001 listed anywhere. Would you be able to measure the diameter of both sections and us know? I suspect - but I don’t no for sure - that the stump is 4mm and the pusher is 3mm too. It would be interesting to confirm. Thanks Malocchio.
Do they actually make the Horia clone in 3mm too? Mine is 4mm both sides and I thought they all are. Yes 31001 fits the 4mm model and works great. I use it for seconds hand tightening too.
By trenchwatchww1 · Posted
have measured up and movement looks to be 28mm diameter...a number of silver case reads 237516 there is a nother mark i cant make out
