It's a fascinating exercise to go through the specifications of modern mechanical watches and look at the availability of various kinds of movements. Something I do from time to time. (As you can see, I've got far too much time on my hands - no pun intended).
As far as mechanical movements are concerned, the choice is predominantly automatic - perhaps 96% or so - and I wonder why. Is it because they're less complex  and thus easier to service than a hand-wound movement? Less likely to go wrong? Impossible to break the mainspring? Just the current fashion?
I only have two autos in my collection - simply because I prefer the more obvious "availability" in visual terms - of a hand-wound movement, so I'm not a huge collector of these watches.
Comments welcomed!
Cheers,
Will
I've wondered about this as well..
Most mechanical watches now are lifestyle accessories and there's nothing simpler than grabbing a no-date hand wind, winding it up and wearing it for a day!
Elegant on the wrist and equally at home in the office or at social events. I also enjoy the tactile pleasure of winding up a quality handwind. I currently have a dress Longines on my wrist as I'm writing this.. The case and dial have seen better days but the cal.280 winds butter smooth. I haven't timed it as its not worth the effort as I only wear it for a day or so but its accurate enough to get me thru the day!
Once i'm done for the day.. Back in the box it goes until the next time.
Autos only make sense if you wear it every day..
This brings me to Seiko's... While I love their designs and the quality of their movements is good, the lack of handwind facility is a pain, when I want to wear one of my Seiko's I have to shake it for something like a good minute to build some power up!
Anil
Hi Will.
From a performance point of view, an automatic watch should keep marginally better time than a manual if it is worn everyday. The force supplied to the movement should be more constant due to the spring continually being wound.
I can't agree with two parts of your statement "less complex" and "less likely to go wrong". By virtue of the fact that there are more working components, and that these components are having to perform under relatively heavy load compared to the rest of the movement, both reliability and mechanical failure are greater. I do agree that the spring itself is less likely to give fail.
Unlike yourself my watch collection is probably split 50/50 manual to auto.
    • The odd time that i have slotted a screw head, was using a 15mm  0.2mm diamond disk.  Gently hammered the screw into a 6mm timber rod, then fed that into the cutting disk. The timber helps to stabilise and keep the disk on track with the screw centre.
    • Still valid, could you please post a picture of your plate? If I cut a slot with a saw by hand, I hold the pinvice with screw clamped in a vice. Then start cutting at the edge, holding the saw tilted 45°. This provides a starting point, from there you can align to the exact middle and proceed cutting. Frank
    • Hi everyone!! It's been a while since my last post... and since the last time I found time for my favourite hobby. Finally, I'm back on the bench -- and with something very special. So, I have this amazing Rolex Explorer 1016 (from 1969) on my desk. I had already noticed before disassembly that there was a tiny dent in the lume in the "Mercedes" hour hand. And, of course, when taking the hands off, it broke. It's just a TINY hole, but with the black dial, it is noticeable. I definitely don't want to remove the original and beautifully aged Tritium lume (which matches the dial and other hands).  But is it feasible to just fill the tiny hole? Or does the application of lacquer/UV-glue likely risk damaging or discolouring the old lume? I was thinking of using coloured chalk as suggested by @nickelsilver, mixed with lacquer or UV-glue. Sorry, picture isn't great. I can add a better one later.
    • Nev‘s advice would be my first idea, too (or even changing the whole overcoil, as the straight sector is too short). However the coil is already almost straight there, more straightening hardly advisable. But assuming the up-bend (the „knee“) is at the red arrow and realizing that the gap between coils is too wide there, I would first bend at the yellow arrow, the other end of Nev‘s yellow line. It not yet enough, go to Nev‘s end of the yellow line. Frank
    • Hello and welcome to the forum. Enjoy.  Depending how deep you want to go have a look at the watch fix courses run by our Administrator Mark Lovick.
