Help with 1960's Gruen Air Flight Jump Hour Wrist Watch
By nickelsilver · Posted
The overcoil can have a number of forms depending on where the stud is situated in relation to the spring. Here's a pic of the Phillips terminal curves. The pdf has all the curves in different scales, you can actually print it out and lay the spring over the one you determine you need to help in forming the coil. It's in 4 languages too! PhillipsTerminalCurves.pdf -
With the balance removed and the watch wound, does the pallet snap back and forth? -
Remove hands dial and have the movement out of the case remove the balance complete and pallets, make sure the train runs free, with these old Russian watches they have different length screws so make sure you have the correct screws for the parts. Are the pivots good and not bent what about the jewels you need to check everything.
Hi All, my watch - raketa (2624 movement) Now the escape wheel can't move itself. If i blow air to balance wheel, the second hand can move . https://drive.google.com/file/d/1ykpAf63N2BUtvVVu1jra0p9hZP4xh9d-/view?usp=drive_link I have reinstall the click from mainspring barrel and the setlever and clutch lever. The other parts is unchanged. is it a problem about release all energy of the mainspring? How can i restore it?
Here's a size chart. 40mm is about 17¾L. I looked in Bestfit but couldn't find anything close.
