Here is a clock from my inheritance.  It still has the customer ticket attached and it appears to have been from the very early days of my dad's business.
It is ticking, but not keeping good time.  I want to service it but am confounded by its construction.
Hoping maybe someone has seen this before and can offer advice on taking it apart.  I dont want to break it through experimentation.
The winding key also functions as the setting key...like a watch, so that means the long stem is mechanically attached to the watch and there is no detent or screw visible to release it.
The sight hole exposes the regulator, so it is not associated with disassembly.
I show front view, bottom view, and back view.
25 minutes ago, watchweasol said:
Hi First one I have seen looks like a big pocket watch. The peripheral screws on the cover look like the entry point to release the back cover .
First removing the hardware on the bottom as shown.  Then removing the two screws that hold the dial plate (two screws are missing), the whole mechanism should slip out.
That still leaves the issue of removing the stem.
I am moving slowly so as not to mess this up.
To me this looks like a hand made put together movement and case. Unscrew this section and you should be able to remove movement from case. Remove hands and see if the movement is held to the dial by a center screw.
1129083471_2022-07-0607_29_03-20220706_072608.jpg-Photos.png.515dc13898b430c3d2876d4df534092a.jpg
I have found this clock on the web, so it is not a one off.
You suggestion is my current plan. It is running fine but I am dying to see inside
llooks like a weird version of a  Waltham  car clock.  Now is the car clock the back would unscrew off the movement but I can't quite tell from the pictures whether that's going to be true or not..
iif it's the car clock it's just a  really big pocket watch.  A very large pocket watch that I'm not a fan of..  But if it is the car clock you should be able to remove the stem that should come out like a standard pocket watch them.. In the movement comes out however it's mounted and then  you can see how it comes out of the case..
No, because, even though there are three screws that release the cover from the dial, the stem goes through a hole and there is no way for the cover to removed before removing the stem.
The stem locks in two positions...just like a wristwatch, so there is something engaged with the stem so that the movement is not going to just slide away (like on some, or perhaps most, pocket watches).  I just feel like something has to release the stem from the movement.
  • 3 months later...
Finally got back to this today.  So trivial.  I just removed those nuts at the bottom and the whole stem assembly slides out.  LOL.
Here is the movement.  I am printing a movement holder for it so that I can work on it today.
As it turns out, the stem just slides out.  No stem-release required.
4 hours ago, oldhippy said:
Look out for wear in the trains pivot holes as its not jeweled and the pivots too for roughness.
you have to be careful with this watch because as pointed out it is basically a seven jewel movement. Then it has two really huge mainsprings driving a intermediate wheel and then that drives the center wheel. it basically is a very peculiar watch but despite all that power the seven jewel version can definitely have running issues.
Yeah, those mainsprings, have not figured out how they work together, but I haven't tried to analyze it yet. A new adventure! I love this stuff
Oh yeah, I see.  The two mainsprings are running in parallel.  Interesting.  I guess this was somehow better than one larger, more powerful, mainspring.
This movement has no jewels.
I think the first time I took power off, one of the wheels (not pivot) got bent a little.  I have corrected it for the most part.
There is no easy way to take power off on this movement.  The click is hidden, and because the two springs are in parallel and not equal, there can be tension on one and not the other.
Edited by LittleWatchShop
I have a friend who clicks military timepieces so I ended up working on the occasionally and to be honest I absolutely despise us. They're basically to deck watches over very common and that's the one by Hamilton which has a really big mainspring it's about 3 feet long and then there's Waltham and one big mainspring like Hamilton has so much better than this arrangement. but for Waltham it's a popular design they were found in car clocks military timepieces your clock they made a law to use of these.
then there is no jewels on the gear train but there is the standard seven jewels.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
