Novice here. And thanks in advance for any advice.
Recently entered the world of watch making, and since I know little of nothing, I have a question.
I decided to start with pocket watches, and I have an old Waltham pocket watch I am working on.
It is running super slow (around -250s/d with the regulator in the middle)
The two balance wheel timing screws are turned all the way out. And the main spring is apparently gunked up. It winds stiff, and unwinds like it is caked with old grease.
So, I am going to tear it all the way down for a thorough cleaning.
But the question is - what happens when I adjust the regulator.
I had the regulator maxed out to the + side so running about -40s/d.
But when I barely move the regulator, IE just nudge it, The s/d may go to +200 for a short while then settle back down.
I have other pocket watches that don't jump to this extreme.
So, I am wondering if this is a problem with the regulator pins or something else?
Whatever strange behavior happens in its present state means little or nothing.
Only after it has been cleaned to perfection, all parts inspected and found to be good at least, then put back and lubricated correctly, you will be able to make meaningful observations about its performance. And It will be better that you use a timegrapher to make calls at that point.
BTW if you really care about this watch it would bw better that you practice first on something else of no value whastoever, especially about hairspring and balance handling.
Thanks.
I have a few pocket watches to start with. This one is nothing special.
And I have been into a couple deep enough that I feel fairly comfortable doing a complete tear down on this one.
I do have a timegrapher.
Welcome to WRT forum.
Timegrapher results be nice.
 Release barrel power through the click so oscilator wont run, then hairspring should not come to contact with neither the boot nor pin, as you move the regulator arm throughout the entire terminal curve.
The transiant state you see can be due to such a contact momentarily throwing the oscilator out of beat.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
