Making A Watch Bushing
clockboy
Find below a vid on making watch barrel arbour bushing. Interesting techniques with the graver especially how he uses the graver to get a dead parallel cut. Noticed though the final drill (when it parts the bushing) does not go completely through hence the broaching required for the final, final fit. This technique is how I make my custom bushings for clocks.
As an engineer, it never fails to amaze me seeing gravers used like that. It looks more akin to wood turning than metal turning. I still use a cross slide and tailstock, just because that's what I know best.
The part that he makes look easy I struggle with Is the parting off. I always have to turn the almost finished bushing around & finish this part to get a nice finish. I wish I had a tailstock I could rely on (mine is out end to end & touch) then centre drilling would be so much easier.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
