Hello all!
7 hours ago, grsnovi said:
Welcome to the forum!
How old are your boys?
@LittleWatchShop is also in Texas. Folks are from all over and all are helpful.
Gary
Hey Gary!  Boys are 10 and 12. They’ve completed level 2 - taking apart a standard movement and putting it back together - on their own without help.  It’s a good way for us to bond before they have to leave home in a few years.
6 hours ago, LittleWatchShop said:
Welcome! Class of '77 here.
What part of Tx?
Howdy!  Class of 2000. We live in College Station.   You?
Edited by aggiedds
Wimberley,  but I also have a home in CS...in fact, I am in the  CS house this weekend. We should get together at some point!
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
