Sorry for the picture quality, I can't seem to get it to focus today.
The two triangular cap jewels:
What type are they and do I just rotate them from inside of the brass setting or am I supposed to interact with the setting, somehow, removing it from over top of the jewel?  Rotating them makes sense but I didn't want to just start shoving them around (I have no replacements).
Thanks for your time.
Shane
Edited by Shane
It would be nice to have of who made the watch that would help if were trying to look up information.
Then a lot of the jewels aren't meant to come apart. Even things that have Springs a lot of time are not meant to be disassembled. So basically it means you clean them when they're assembled and your oil from the backside. Fortunately somewhere yesterday we did do a discussion on oiling from the backside which would cover the situation
What I am working on is a Felsa 1560, 25 Jewel movement.  I tried gently nudging a jewel but it didn't move with what I thought was a fair amount of force.
After cleaning, I looked a bit closer and it appears that the brass ring has a triangular cutout that resricicts any rotation of the cap jewel.  It will not rotate out of position from the three retaining tabs without a vertical movement (unlikely).  The two parts snap into an annulus around the inside of the setting.  Disassembly does not look possible without damaging it irreversibly.
I'm leaning towards oiling from the back.
Shane
I also came across similar jewels in Accutron 218s. I was told to leave them alone and just clean them in the ultrasound. I suspect the 3 notches are not designed for any special tool to remove them but to allow cleaning fluid to circulate between the cap and hole jewel.
I oil them from the hole side.
I took a quick look at the 218 service manual as I thought it actually said that I don't see it. But I do know that they were specifically designed not to come apart. The notches are specifically for the cleaning fluid to get in. They have some other versions that have little spring is on top that look like their shock protected but the spring is only to hold the end stone in place and they Not were meant to come apart either.
This is where if a service manual existed for the watch it would probably tell us don't take this apart because. But then we end up with a lot of watches that don't have service manuals and somehow you're supposed to know what you're supposed to be doing even if you do not. Basically stuff like this represents a problem for everybody.
Shane
Eyup Shane . Good policy to have mate don't force anything. If it looks at all risky take your caveman mentality down a few notches when he starts to kick in.  I'm fact take him out of the equation altogether, it just won't end well. Ugg doesn't have the faintest idea what you are doing or what you are dealing with. The closest he ever got to  the concept of time is when it got dark it was hit the cave floor.
I find the holes in the 218S HectotLooi posted interesting.  They don't appear round but multifaceted instead.  That was not free or as easy as putting in a round hole.  It had to be broached or upset into that shape.  Why did/would they do that?  This is going to be taking up some mental horsepower today or at least on the morning commute.
Thanks for the input.
Shane
Yeah, NO.  I blew it up on the large monitor at work instead of looking at it on the small screen of my phone and it just looks like they did a poor job of deburring the holes.  There is a similar pattern around the hole to the right yet the hole does looks round.
18 hours ago, grsnovi said:
I don't think the jewels in your original photo look anything like the obviously round jewels
Yes, I believe they were just being used to prove the point that some cap jewels do not get removed upon pain of resetting.
Maybe those are marks left by someone trying to remove the jewels.
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
