Leave it as it is. Beat rate spot on, even trace, great amplitude.
If you need to fiddle with it, the crown tube could use some cleaning and since the back has to come off to remove the crown then a new caseback gasket as well.
I imagine you know about the stem release for these watches? the crown needs to be in the time-set positiion and the release pressed in only as far as the slots on the side. Any further an you will need to remove the hands and dial, keyless stuff and daywheel to reinstall everything.
Anilv
Edited by anilv
On 9/26/2022 at 5:43 AM, Paul80 said:
Wow a thousand pound watch and the stem removal is booby traped by poor design 😎
It has absolutely nothing to do with Sinn. It's an ETA 2824-2. The same is true for other ETA movements, for example, the 2892-A2. Anyway, the slot is actually a good design which will prevent you from pushing the setting lever button too far. That is, you use a suitable screwdriver to push the button. However, it's not super-sensitive. You can push using for example a pointed piece of peg wood, but then you have to pull on the crown continually and stop pushing as soon as you feel the stem is coming out. Sometimes, but not often, this is even necessary when the slot (for some unknown reason) is slightly too shallow.
Yeah, I don't like it myself but sometimes you dont have a choice. At least the date-jumper spring is has a good design where you can assemble the jumper and its associated bits and then get the date ring in place by utlising the gaps in the cover-plate to allow the date ring to go in place. Very handy when when you f-up the stem insertion and have to remove the hands/dial/set lever spring plate and date-ring to get the bits in alignment again!
Also on re-installing you need to press the stem release a bit to ensure you don't dislodge the clutch wheel from the set lever.
Easy enough with new watches but on watches that have been 'worked' over on it can be a bit tricky.
Anilv
edit. I have realigned the clutch wheel by removing the barrel and barrel bridge but its too much hassle. Might be required if the dial has been glued down etc.
Edited by anilv
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
