Greetings to all.  My name is Todd.  Married with children (great show right!).  Long time admirer of mechanical watches. Now taken up the hobby of repair.  Why?  Educated at Purdue University (Indiana) and Lawrence Technological University (Southfield, MI).  29 years in automotive industry, first 15 in product development.  So basically my mind has always been curious about how things work.  I see how the evolution of the mechanical watch has occurred.  Amazing.  I have inherited an 1800's swiss cylinder escapement that was non-working.   It is my first project and I am happy to say that it is running again now after some creative repair in the main spring housing to click interface.  However, this classic is missing on the dial side the reduction gear for the hour hand and the actual minute hand.  Seconds hand and hour hand are ok.   As reference, the movement OD is 44.9mm, the cannon pinon OD is 1.15mm, the seconds hand shaft is 0.6mm and the post that supports the missing reduction gear is 0.49mm.  Basically I could use some hints where to search for parts!  Attached are some pictures to compliment my words.  I appreciate in advance any advice.
Edited by ToddABrown
Hello and welcome to the forum.  the watch is a five bar french/swiss made cylinder movement  you will probably have to trawl the net/ebay for bits.  I believe Old Hippy mentioned that these are the devils own find bits for as they are almost individualy made and as such parts dont interchance easily or not at all.
Hello and welcome. I'm a reasonable newbie myself, servicing I'm getting good at, repair is a different matter.
Unfortunately the parts aren't always interchangeable, in fact seldom are. I've learnt the hard way.
Edited by RichardHarris123
Typo
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
