Avoided Covid-19 but caught Watchmaker Bug
Hotdog
Hi, very pleased to introduce myself as Richard, who has become obsessed with watching watch repair and refurbishment videos...
I am kitting myself out with the tools I will need to enjoy a new hobby. Stuff like a Timegrapher, ultrasonic cleaner, case back and crystal tool, screwdrivers, tweezers, and lots of other tools and things including loupe, polishing equipment, microscope and even macro lenses for my camera...
One thing I haven't been able to get a handle on though, even after some Internet searching, is why, when so much effort goes into special oils and greases to lubricate spring friction points, pinions, jewels, mainspring and the components in the keyless works, etc. the gear teeth on wheels are left dry?
I would really appreciate an insight on this please. 🙂
Welcome to the forum Richard.
That is a good question. Initially I may have said brass (gear) against steel (arbor) does not have a lot of friction, but that does not follow to a pinion (steel) in a movement plate (brass). The only difference here is the size of the diameter. However, unless I am greatly mistaken, as the diameter decreases, the percentage ratio of steel to brass contact increases.
Jewels are used as the friction between a jewel and steel (pinion) is very low. If so, why the need to lubricate it? jewels are much harder than steel. The oil creates a film between the jewel and the steel that greatly aids in the jewel not wearing the pinion away. That sounds counterintuitive now that I read it back to myself, but I can think of no other reason.
Spring friction points would be lubricated due to the amount of force that the spring has against the wheel that it interacts with. The friction would be so high if the contact surfaces were dry, that the wheel would be greatly inhibited from turning at all. The spring's function is to stop its wheel turning in the wrong direction, so if it is lubricated so that the wheel progresses more easily, that does not have any bearing on the function of the spring.
As I'm knew to this, I may be completely wrong. I'm applying what I know as a mechanical fitter to a much smaller scale.
The  friction created by all the teeth meshing would be too much for the watch if they were all oiled. An oils viscosity applied to micro gearing as opposed to large gearing would have a completely different impact. Lubrication tends to be a less is more approach. More so i would imagine virtually impossible to stop the oil spreading throughout the watch, epilame everything?  It just doesn't seem practical. Even if it did work how much sooner would the movement need a service. Interesting experiment though to see how soon it would stop. Fairly quickly I'm thinking.
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
