With a new watch on it's way to me I thought I would try and find a technical drawing for Tissot Cal 791 it's swiss made right so I thought it would be easy to find one Ha ha think again Tiny I can't find one is there a special place to go to find drawings ?
483462505_161e9af8-59d0-4179-a124-a7d4c287d4fd.jpg.91b92e96baa616aea54fac8aebd29165.jpg
483462505_bf81e44d-a578-4124-a83f-129cd892212f.thumb.jpg.5f400c3c482ea523ea7d3964003323ff.jpg
So I have to shout out to anyone that can help me please
Hiya T.  Did you get the jewels sorted on the Seiko ?
No not yet
I think it came from the second Movement I had on my bench. I can't see any missing jewel holes
My mainspring winder has arrived for the Seiko today so I'm going to wind my barrel tomorrow
Hi @Tiny
Remember to always look around the family your movement comes from where you don't come up trumps if you just use your specific movement reference.
Your 791 is a manual wind no seconds but a 781 is in the same family with a second hand; the 794 an automatic with date. Differences of course but the same basics.
Then Cousins is good for docs: https://www.cousinsuk.com/document/search?SearchString=Tissot. Note 781, 794 etc.
Or google tissot 794 pdf
You get the gist. Hopefully this will get to what you need.
Usually in watch repair unless there's something special about it there probably isn't a technical manual the most you'll ever get is a parts list. Usually the watch companies feel anything that looks reasonably simple that a watchmaker should do it and doesn't need a step-by-step guide. Sometimes the watch companies might have a consolidated guide of several watches but usually they have to have complications of some sort. But it also depends upon the manufacture
Then there are websites like this a online parts listing. If you're lucky they might even still have the part in it can be purchased. But if you're unlucky you can also click on the part numbers and anything get a list of all the watches that use that same part. Often times parts will be used in multiple of watches and he might do a fine those if you can't find your watch in other words if you need apart it really helps to know what cross references to.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=TIS_791
Then next site is interesting it has pictures because often times people don't give us pictures of their watch. It's hard to help people with answers to questions if they don't get pictures you don't did give us pictures that was good. It also gives some technical knowledge like this is part of a much larger family. If there was a service manual but I doubt that there was one often times it would be the base caliber would be the manual your book for and somewhere that might be supplemental on may be. But this one is simple enough I doubt there was a service guide the most you'd ever get would be a parts list if You are lucky.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Tissot_791
Yes excellent advice from “Watchmaker”  & John caliburs develop over time so although they change there are always similarities.. Seiko caliburs being a good example. Over time with experience referring to service manuals only comes into play with a complication.
Edited by clockboy
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
