I had two different tension ring tools one was screw down the other was press I liked the press better. Just to let you know how well my workshop was equipped I even had the Omega glass fitting tool and the Tissot.
Lol, i remember watching that for the first time and thinking Indiana there is no way that small bag of sand weighs the same as the gold statue 😅 -
With a crystal wrench you should be able to insert armoured crystals in addition to removing them. I have this Seiko S-14 but I have only removed one crystal so far. Btw that went really smooth. A lot more comfortable than the brass jaw lift.
I can't say I've found it any better than naptha, why these chemicals specifically for hairsprings ? Just going slightly off topic, yesterday i was sorting out a very poorly balance assembly on a 90 year old AS554. All components of it in bad shape, first to deal with was a rusty hairspring. I did a write up a couple of years ago going through various kitchen items and their chemical make up in order of their aggressive nature on steel. The mildest being citric acid in particular lemon juice, so i thought i would try this first, anything stronger could eat through fragile thin steel very quickly. I used freshly squeezed juice heated on a wax melt heat plate to about 60° and soaked the hs for about 2 hours. Then lightly brushed and rinsed in IPA. The results were very good, the effects of the rust were still obvious but the iron oxide was completely removed. The pictures are the befores.
