Box this was shipped in provided absolutely no protection. I am guessing the prior owner was not a physics major.
Edited by Nibbler
  • Sad 4
Here are a couple of more pictures of the set after minor repair of the box and basic cleaning. I -think- the knob at the very top of the tool adjusts the tension the bit is held at. The other part of the box, actually the bottom, needs a little more basic repair.
Matt
9 hours ago, watchweasol said:
What a mess  a bx rebuild required,  a shame some people have little common sense.
In spite of its name Common Sense is not so common 😉
Matt
Doesnt  look too bad nibbler. What make is it ? The punches look ok. What is the striking end like ? This should give you an indication of how much use they have had
1 hour ago, Nibbler said:
I believe its a K & D. Very few piece show excessive wear.
OCD level 3 and still not finished:
Looks like you have a balance staff remover thrown in too. 👍
I bought the balance staff removal tool first then realized I needed the staking set. lol.
Buying more tools never seems to be a problem.
Matt
Yup. It's like the song from The Greatest Showman.... Never Enough! Never, never...
Matt
Only when you are threatened with divorce. Thats why I'm single 🙂
On 5/17/2022 at 6:40 PM, watchweasol said:
Now is assembled and more or less in one piece its looking quite complete including a K&D balance staff remover. A good purchase that should last for years.
It's lasted longer than the box 🤔
I had exactly the same thing happen to me when I purchased my first set on eBay. Seller left all the stakes and anvil in the box with resulting breakage of box.
At least your anvil and stakes look to be in very good shape on your set—enjoy (I use mine way more than I ever imagined I would).
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
