Greetings,
I've recently acquired a vintage Speedmaster that has some unfortunate damage to it. See a video of the damage at this link:
https://imgur.com/a/rGWQG4K
I'm struggling to see what's actually been damaged here, if it's part of the dial or something else (tension ring?). It's under the glass right on the edge of the dial (see image).
Would love to just know some more on this, what's exactly damaged, if it's an easy change (e.g just a replacement or fix)
Thank you.
5 minutes ago, Watchguy2 said:
Greetings,
Thank you.
From the second photo does look like a broken tension ring. Does the crystal feel secure ?
Yep, feels secure!
What does this mean?
Edited by Watchguy2
I'm not sure I've ever seen a broken tension ring? Now it could be a broken poly propylene or whatever the plastic gaskets are that holds the crystal in place they can disintegrate. The normal tension rings: the inside their metal and I don't think I've ever seen one go bad but this is watch repair everything is possible.
Then I didn't see any back pictures like a picture of the backside where we can get a serial number or a case number although usually case numbers inside the back but serial number would work I can look up how the crystal holes in place but I can't do it without a number.
Thank you john. I do agree the tension rings i have come across have been of a mild type steel so are more inclined to bend as apposed to a hardened brittle steel that would fracture. So could this be of a non tension crystal type fitting ?
No identifying numbers on the back besides the strap.
Problem is I went back and looked at the pictures and it's really hard to tell what were seeing. Although if it was a plastic crystal it would have a tension ring. If it was some form of glass or worst-case sapphire because Sapphire would be astronomically expensive then there would be an outer Polly propylene ring holding the crystal in place typically.
But the best way to do an evaluation is to take the back off the size we would get the case back number from the inside. But taking the watch apart does bring up a minor problem like?
Recently acquired was it expensive? Casually one is looking for a crystal the seems to be an expensive watch I wouldn't really recommend it for your first watch repair. Even taking the movement out could be interesting if you've never done it before and Omega watches the parts are astronomically expensive if you can find them. As they have restrictions on who can purchase those parts.
Thank you for that information. I have been looking at ebay and drooled over an Omega as an idea for a future project when I have experience. Thank goodness I saw your comment.
Regards
Ross
It was a gift and came as is. Is it something I could send off to get serviced and they can fix it then?
Dont know if I'm prepared to open it myself
Edited by Watchguy2
You would maybe want to weight up the cost of having it repaired against leaving it as it is and just being careful having it around water as the broken seal tension ring ? will affect its water resistance. Tbh i would never have water near a vintage watch full stop. But as John says too expensive to try to repair yourself without any experience .
I wouldnt open it yourself. Not without a good amount of learning and experience under your belt.
Edited by Neverenoughwatches
Thanks for the information. At least I know it can be fixed if necessary. Will have a think
The bracelet doesn't seem to match the watch, it seems far more modern. Do you know much of the watch’s history?
Depending upon the country you live in you may have a Omega/Swatch group service center. I have a link below it talks about the servicing of you send the watch in it is completely restored the movements restored faulty components are replaced the case is stripped refinished everything is you basically get a brand-new watch back.  But then there is the problem this isn't a cheap watch and the servicing is not going to be cheap I used to think they had the price list on the website but I don't see it there probably because too many people had a heart attack and were unable to send their watch in. Although considering what you get and they have original parts it is typically a good deal it just isn't cheap
https://www.omegawatches.com/customer-service/interventions-and-prices
If the crystal has been replaced with an aftermarket one the original ring could have been cut to reduce its diameter, an original crystal should have the Omega symbol in the middle.
Parts are availabel but pricey and you need a friendly watchmaker to get it for you.
Anilv
Anilv
A replacement crystal would come with its own ring wouldn't it? It's probably just a generic type that's too small.
The last Omega crystal I bought had a ring inside but that was for a seamaster not speedmaster,
Anilv
Anilv
Crystal is original. If I get it repaired, would they need to change that?
Edited by Watchguy2
I don't suppose you've got specifications for your watch? Like what kind of movement is in that case for instance?
All you have to do is take the old crystal out you would have to have the case number to get the proper Crystal. The crystal of this type is listed as a Plexiglas crystal with a black ring. You would just need a crystal press to the right type to push it in.
Plastic crystals have a lot of stress and this will eventually show up as a lot of hairline fractures on the crystal. If you are saying you want to save the original I would recommend not bothering they are considered consumables. Get an original crystal installed by a proffessional is the best route. Not much difference in price to buying one from them and installing  it yourself.
Anilv
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
