What type of crystal is this? The case pushes through the back and the crystal essentially hugs the outside of a lip at the top of the caseback. I've come across there before but have always been lucky enough to just polish the existing one and have never replaced one. The one on this watch has some bizarre crazing going on and it definitely needs to be replaced, but I'm not sure how to find one. This particular crystal measures 29.4mm in diameter. I tried taking the ring out of a tension ring crystal as a kind of work around but the smooth space where the ring was isn't deep enough to hug the whole lip. Thanks for whatever advice you can give!
I had one of those on a 40s Certina a while back. Major PITA to find a replacement... I took very careful measurements of all the critical dimensions, then looked through the crystal manufacturers' catalogs. All of the required measurements aren't always published, and I ended up calling the company that had the closest match across a small number of the specs that were published, and told them the third critical dimension. She did some digging, and came back with a couple that were close on either side. I got both, and ended up needing to carefully reduce the outer dimension until it fit snug, but not so snug I couldn't get the case open/closed again. Not my favorite means crystal replacement, but doable.
  • Thanks 2
On 5/6/2022 at 3:59 PM, Kalanag said:
I think it’s a „Sternkreuz XS Stülpglas“.
This may help:
Thank you so much! Very helpful!
That's a good idea, thank you so much!
May I ask what was the method you used to reduce the outer dimension of the crystal? I am in a similar boat, but am not sure of the best way to go about it.
Either scraped with a razor blade (hold it at a 90° angle to the surface and it'll pull off fine shavings) or fine grit sandpaper. Don't recall what I ultimately went with... followed by crystal polish. Didn't need much.
  • Similar Content
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
    • Wiggle it back and forth, small steps, keeping the pallet cock as level as possible and take your time (!). You could also use an extra tool as a safeguard at the jewelled end to avoid pressure on the pallet fork. You also mention lubrication... On the pallet fork pivots??
