7750 not working - gear train issue?
Hi, I’m new to this forum and hobby. Looking for some help from experts here:
- modified 7750 movement (6 and 12 subdials not used)
- not working with manual or automatic winding
- I removed the balance wheel and fully winded the movement
- then I gently move the fork up / down, up, down and everything works fine - escape wheel is moving. However if I continue, after ~20-30 cycles of manual moving of the fork the escape wheel doesn’t rotate anymore - I continue moving fork up and down but the escape wheel is not moving.
-then I wind the movement a bit more - or even just very gently rotate the crown - like 5 degrees or even less and then the escape wheel starts moving again when I continue moving fork up and down - again 20-30 fork cycles and the escape wheel stops moving again
- originally I thought the issue can be with the main spring but it is winded fine - if I “unlock” it it rotates very fast - has enough power reserve
- so my thinking is that it is probably something between the main spring and the es ape wheel - gear train?
- also I tried to remove the automatic winding - back side of the 7750 - rotating weight and the wheel but no change
any recommendation what can be wrong or what else I should check to localize the problem?
It sounds like friction in the gear train. Let the power down in a controlled manner and remove the pallet fork. Wind a little power on. The escape wheel should spin and come smoothly to a stop, even reversing slightly at the end. If it doesn't spin, remove it and do the same test on the fourth wheel, and so on wheel by wheel back to the barrel.
Disassemble everything. Check for wear, damage and contamination, especially at the places where you found the most friction.
Reassemble, lubricate and repeat the test.
Never "unlock" with power in the system.
Thanks - so I tried to remove the fork and wind the movement slightly. What happens is that the escape wheel starts spinning but only for a short time. Actually when I do more winding it seems that the escape wheel is still moving only for a short time (independently on how much I wind). So I think the next step is to remove the escape wheel and check if the fourth wheel is moving.
Unfortunatelly the escape wheel is positioned low so I would need to remove all upper decks (marked 1, 2, 3, 4 in attached photo) - which I'm afraid off...
Wow, it seems it helped. I slightly loosen the screw on all 4 plates (see photo above) and the escape wheel runs well now. Also attached the fork and later also balance wheel and it is still running - great!
Unfortunately I can't say which screw helped. So I thightened all of them again now and the movement is running fine.
Well... after 5 minutes it stopped moveing again 😞 So I loosen all screws again and now it is not running...
Not sure if I should remove the balance wheel and fork again and try to repeat the same while keeping the screws a bit loosen...
 You released pretension forces in the plates, allowing space for any bent pivot, depthing ... etc to run . Usually pretension is due a bend in the plate caused by tightened screws.
To find which screw/screws are causing this pretention.  Loosen all and tighten one at a time, then tighten and loosen one at a time. Once spotted shim the plate near or opposit side of the screws causing the fault, shim material must be real thin.
Lets ask @nickelsilver to correct me if wrong and his advice.
This all is true only if end shakes did exist when you reassembled.
 Shakes should be checked during disassembly/ reassembly.
Regds
modified by who? Who made this movement?
Then the problem you're having did it just suddenly happened or did you purchase it this way when did the problem pop-up?
Regds
what do you mean by end shakes please?
Maybe I should mention that I should use it without oscilating weight
I bought it knowing it is not working and trying to fix it. It is asian 7750.
End shake is the axial free play of any arbour or balance staff
Check end shake on all arbours of gear train including barrel that of the barrel.
Adjusting a jewel might be all your watch needs.
Do you have a data sheet and diagram for 7750?
Wont hurt anything if you tighten the screws.
OK, that's understandable. If this watch is worth anything to you, my advice is to either take it to someone who knows what they are doing or put it aside until you have acquired the experience and confidence yourself.
the problem with clones are how well were they cloned?
Then next problem of it's been modified was it ever running in the first place?
then there is the amusing problems? Amusing might not be quite right word but this is a chronograph it's complicated really complicated yet you seem to be missing the chronograph components? That's going to make it a lot simpler. But you still have amusing things?
for instance in not using the oscillating weight but if you look at the service mail but I  have down below that's not normally the way the oscillating weight is disassembled? Normally the screw what a come off and the ball bearing assembly would I go on with the weight so if it's just sitting there all by itself it makes you wonder how many other things have been not quite right?
ct_7750_esi_465853_16-1 13.08.2019.pdf
Thank you all for your comments and feedback. While I’m a complete beginner in this hobby I can accept the risk that I will damage this movement. I just wanted to give it a try to fix it.
i tried to loosen and tighten all screws on the plates but no success. When I very gently wind (just a light touch) the winding in the ccw direction the escape wheel moves with me moving the fork up and down. But always only a few cycles.
I think I need to again remove the fork and investigate what happens to escape wheel to start moving again.
what should I imagine if you say “Adjusting a jewel”?
i think the issue is really in the gear train so I need to find where is it and what to do with it.
What is strange is that when I loosen the plate screws it started moving, so I assembled again the fork and balance wheel, tightened the screws and after 5 minutes it stopped. Loosening the screws didn’t help now so I thing removing the fork again is what I should do.
You will need to do a complete strip-down, clean, parts inspection, step-by-step rebuild and functional checks at each stage to diagnose the problem(s). Depending on what you find, you may or may not have the equipment or skills to correct the faults. If you are still curious enough to proceed despite the risks, there are plenty of people here who will assist you as far as we can. Just be aware, there is a good chance of you introducing new faults as well as not resolving the existing ones. On the other hand, faint heart never won fair lady!
That's how I got my missus. Brave and bold got me  a  beauty
2 hours ago, vcelkamaja said:
.what should I imagine if you say “Adjusting a jewel”?
You move the jewel in or out in the hole its in, so to create some end shake needed for gears to turn effortlessly.
It would be nice to show in a vid what you describe here,   A picture is worth two thousand words.
Hi nucejoe. I'm looking for a jeweling tool.  Would you recommend one with a hand lever as opposed to without for better depth control. Bit off topic but I thought I would grab an opportunity to ask you.
Edited by Neverenoughwatches
3 hours ago, vcelkamaja said:
I think the issue is really in the gear train so I need to find where is it and what to do with it.
Yes,the issue is in the gear train and is very  likely an end shake one and we are trying to show you how to spot it.
It's a pity we can't post a video. I've got a great one I show my students how to check end-shake, filmed under a microscope
So, if when the screws are screwed tightly, you may have the jewel Shown in red in the pic) which the pivot passes through bind tightly against the shoulder of the pivot (which passes through the centre of the jewel shown in red) which doesn't allow for any up and down movement of the wheel, therefore the power can't flow properly, stopping the watch. Sometimes the jewel has moved and needs pushing out to regain that end-shake, which really requires a special tool. It could be either the jewel in the mainplate or the bridge, so either top or bottom jewels, so with tweezers you would hold the spoke of each wheel and see if it can move up and down slightly. you should feel it more than see it. more end-shake on the bigger wheels and less on the escape wheel and balance.
I must say, I like your enthusiasm starting with a 7750, regardless of being a clone or not! He who dares, wins!
BTW, that was a slide from a lesson regarding oiling, just in case you thought what oil had to do with anything... lol
Edited by Jon
While I have no advice for your issue, as I am a beginner hobbyist myself, I recommend you watch some of the videos on this YT channel: https://www.youtube.com/c/ChronoglideWatchmaking. There you will find a wealth of watchmaking knowledge from a professional, including all about end shake and how to adjust it.
Apologies for my late response, just didn't notice your post.
 I hope we get a good advice from those who know.
Regds
Thanks for all support. I ended by "merging" 2 different 7750 movements into one. I took a new asian 7750 and removed some parts - date wheel, top plate,... and replaced them with parts from the non working 7750. It seems that everything is ok and works fine now.
The only "issue" I have that it seems that the 9 oclock running second pinion pin is shorter compared to the old one. Which is bad as my small second hand has a short tube to be attached to the pin of the new 7750 running second pinion at 9 oclock. Not sure if the tube of the second hand can be somehow extended... I'm also trying to get a new small second hand with longer tube.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
