Lathe work
Welcome to the forum. It all depends how tight the previous person that worked on it has tightened the back but for the price it's probably your first option. Yes it should have a gold bezel fitted.
Thank you for your response. Are you sure we’re not missing a bezel? When I looked on the web I got the attached pics. My wife’s doesn’t look like this. And will the tool in the attached photo work to remove the bezel?
No bezel missing! https://poshmark.com/listing/Tag-watch-61d7616ece1e87f8dc50f907 Replacing the battery ist quite easy. But first you have to unscrew the case back without scratching it. This might be the main challenge for a beginner.
By nickelsilver · Posted
Here's a post showing what the barrel insert looks like. -
There is a metal finger.
