Hi all!
I just picked up this little watch - not running, super dirty inside, but looked too interesting to pass!
doesn’t have any markings on it (aside from “Swiss made on one of the corners of the movement)..
any thoughts on where I can find more details on it?
I don’t have any tools yet so perhaps I could look behind the dial once I can get it off!02122305-42A1-44C7-B3A8-98746734D0F2.thumb.jpeg.edcd0266b1a559d2b8129361dfd0dff3.jpegBC03D193-3773-45E6-A4F1-264CCA679582.thumb.jpeg.a53a9e1970693d9ab518c4932164a2be.jpegC12551E0-13A7-41DD-AC4D-86D6350B2049.thumb.jpeg.67a64e83c9096dcdb5b75e169fa5779d.jpeg55ACB3A7-31CE-4294-A779-26E3EBF7F36E.thumb.jpeg.36cad1aac83f9dc7c8952be715a8787c.jpegDC45F70E-F00D-46BA-8EA5-510E5B98D3D0.thumb.jpeg.3168c3f63f3a01f584801cf422715b6a.jpeg
Hi Its a trench watch and some of these old ones have no markings and were identidfied via the setting lever parts, there are in the bestfit books.
Old Hippy put the links to them on the site and can be down loaded.  If using the search function on the home page and search the term "bestfit" and scroll down the results for Old Hippy's post of Dec 30th 2018 where you will find the links. I have checked and they are still operable and take you to the Meadiafire site for down loading.
You are going to need a few tools to get the movement out of its case. First you need to remove the winding stem, remove the bezel and then the hands, you then need to turn the two screws inside the movement that hold the two dial feet. Be carefull because the hour wheel might just drop off and you do not want to lose that the same goes for the dial washer that might be attached to the hour wheel. Post some nice clear photos of the keyless work that is how a movement can be identified.
Tools needed tweezers, selection of watch screwdrivers, hand removers, if carefull you can remove them with tweezers but not advisable and you will need at least one eyeglass depending on your sight. My advice you will need many.
Very cool little watch!
Will this be the first one you'll undertake for restoration?
Yes I think it will be! It seems simple enough - I just hope I don’t encounter any broken parts along the way!!
thanks kindly for your feedback and suggestions! I have a few loupes coming in from Amazon hopefully by the end of the week - the screwdrivers and tweezers are already here, and the hands removers are coming in from (apologies to all but I’m new at this!) AliExpress.
once it’s all stripped and in parts I’ll take some better photos and share my progress!
Awesome! Thanks for the suggestion. I noticed I got a response by old hippy as well!
i Have found the documents referenced. Unfortunately I’ve no idea how to use them! But I imagine I will need to find amongst the movement some sort of identifiable reference, or similar.
thanks again to you all for your quick responses!
In order to try to find the maker you first need the size of the watch and then reference it to the identification section of the book. Having the size cuts through a lot of information and focuses on the relavant shape and size. then cpiple that with the keyless works image using the setting lever spring shape  to home in on the maker.        cheers
It'll be well nigh impossible to establish who actually made/produced the watch. However, the movement itself is reminiscent of something from Adolf Schild, like the "old"version of the 10.5''' AS 373 which measures approx. 23.7mm in diameter and was in production from roughly 1920 (or earlier) to at least 1928 (or later).
However, whilst close, the AS 373 is not an exact match (e.g.the position of the stem release screw, whatever else) but as stated above, a clear image of the keyless works should help identify the maker of the movement, if not necessarily the producer of the watch.
Regards.
Regards.
Hi WS welcome to the forum. Take a good macro photo with each part you remove, it really helps with reassembly.  Keep your parts removed bridges and cocks grouped with their screws (not all screws are the same) initially anyway, as your experience grows you will get a feel of which screw goes where. As your train wheels come out note their order of removal and their vertical orientation. There is generally a set order of in and out of the movement and its also easy to try to put them back upside down. Sounds obvious but trust me it does happen. What you are working on here is probably  a little easier and more obvious with it having seperate cocks and bridges for the train wheels as opposed  to one bridge for many train wheels. Be careful with the smaller of the steel cogs, so NOT the one with the 2 holes and the small clic . The one that is next to the crown
.(the crown wheel) The screw on this may be a left handed thread , in many cases of vintage  watches but not always. I'm not sure how far back that came about. Sometimes it's indicated with 2 extra lines alongside the slot of the screw but again not always. So be a little careful with that one, just a gentle twist each way until you discover which way its threaded. I'm just wondering if the screw head has broken off on the ratchet wheel ? Could this also have been left handed anyone ?  Keep us informed of your progress and always best to ask before doing something  you are unsure of it can save you a headache. Ps. Sorry I just realised I addressed this to balaton, I'm terrible for that🙃
Edited by Neverenoughwatches
Wrong person quoted lol
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
