This is the latest Mumbai special that I have been working on. It's a Titoni Airmaster 25 jewels Rotomatic.
It was supposed to be fully serviced, fully working and inspected just before shipment. But sadly, it wasn't working when it reached me.
It couldn't wind automatically and winding it manually causes the rotor to spin.
I have disassemble and recleaned everything. The winding and helicopter effect problem have been resolved. Now the only problem left is the balance staff. There is an endshake of 0.11mm on the balance wheel.
I've checked Ranfft's website and there are supposed to be 2 versions of the 2452, a balance wheel with screws and a smooth balance wheel. And so there are 2 versions of balance staffs. The one I require is supposed to be a U3136. Is this a Ranfft numbering code?
Cousin's has 2 versions of balance staffs for the 2452.
https://www.cousinsuk.com/category/filter/eta-movement-parts
Which would be the correct version for my watch?
TIA
Are the balance pivots broken? Why are you changing the balance staff? You can change the balance endshake by moving the mainplate balance jewel slightly further in.
17 minutes ago, HectorLooi said:
.There is an endshake of 0.11mm on the balance wheel.
I would be custom know how you have measure endshake with an approximation of 0.01mm
.The one I require is supposed to be a U3136. Is this a Ranfft numbering code?
No. Codes on Ranfft's are Flume (a large German materials house part numbers.
Correct. And even before doing that it has to be demonstrated on the timegrapher and on the wrist performances that endhsake needs adjustment.
I measured the endshake by inserting feeler gauges between the pallet bridge and the rim of the balance wheel.
I've already checked the bottom plate for a way to adjust the endshake but this is a very strange Incabloc setting. The jewel is set in a chaton held by a screw. There is no way to press it in.
The pivots are not broken but seem very short. If you look at photo 3, the balance wheel is almost touching the pallet bridge.
The timegrapher trace is very erratic. Amplitude fluctuates, beat and rate changes with every position. The hairspring stud is stuck in the hole, so I can't tell if the hairspring is centered properly.
I'll fabricate something to press out the stud tomorrow then I can measure the length of the staff properly.
Could you take a picture of the chaton? I’ve never seen in incabloc movement like that.
The hairspring studs in these balance cocks without a stud screw are held by friction very tightly in the stud carrier. It’s almost impossible to press out safely unless you can find a way to support the underside of the stud carrier, but the balance wheel is in the way.
I looked at the Jules database and there’s quite a number of balance staffs listed there for the 2452, with multiple incabloc ones with different pivot sizes? http://cgi.julesborel.com/cgi-bin/matcgi2?ref=ETA_2452
 If it keeps running in FU and FD positions then pivot shoulder seats are not rubbing on hole jewels, so unless you like to renew the staff, this one still has another decade of life left.
I don't think this approach of mine got approval from OH , he once said just put everything back right( he was reffering to my advice I think), but here is what I do and it works.
Flip cap jewel over, so its domed side faces the pivot, this will reduce end shake.
Oil will stay on top of the dome specially if you epilame treat it.
You might need to adjust shock springs to press on cap stones( push on them and bend a tiny bit)  so not to have the jewels loose inside housing of the setting.
Both lower and upper end stones can be flipped over if needed.
Its a lot easier than staff renewal, poise ....
Good luck Doc.
Here you are.
The 2452 has several strange designs that I've not seen in other ETAs. Like the date detent. It uses a roller instead of the usual "V" shaped end on the lever.
And the crown wheel is screwed to a short lever that allows the crown wheel to disengage from the ratchet wheel.
The balance stud actually has a screw but it was missing. I suspect the seller put superglue or Loctite into the stud hole to fix it. I'm thinking of modifying a tweezer to fix a pin on one jaw to press on the stud above and cut a slot in the other jaw to allow the bottom of the stud to protrude through.
Once I can remove the balance wheel, then I can decide on what to do next.
This is exactly the kind of "Mumbai Special" test that my mentor prescribes.
When I tell him about all the problems I find in the watch, he'll say, "Good! Now go and fix it". 🤪
I think the balance stud came without a screw from the factory. I used to have a peseux 7001 that was the same; it had a stud carrier with a screw hole but no screw. The balance stud was secured very tightly in the stud carrier by friction. I think at some point to cut cost ETA stopped using a screw to secure the balance stud, relying instead on friction. ETA left the screw hole on the stud carrier probably because it would cost more to retool the machine.
Interestingly, balance staffs .com has two measurements for balance staffs for the 2452, with one 0.10mm longer than the other.
Edited by ifibrin
How will you change the balance staff even assuming you get the correct one? Do you have a lathe or a platax tool? Some of these balance wheels have a fixed hairspring collet which can’t be removed without distorting the balance wheel.
3 minutes ago, HectorLooi said:
Hmm.... 0.11mm... Interesting number.
Take a look at this: 613F89C7-D59C-43CF-A442-4F26A6D9344D.jpeg.727cb7fa632d40690c136ea7266bbbcc.jpeg
maybe someone replaced it with the wrong balance complete or balance wheel?
I have a lathe, a K&D balance staff remover, staking set, etc...
My mentor has been bugging me to do a staff replacement and cutting a staff from scratch. I've done some practice staffs but not an actual one yet.
Probably when I have my lathe permanently setup with a microscope overhead, then I'll do more lathe work.
Would you be able to show the lathe setup that you have? The lathes I’ve been looking at on e bay look enormous, and are fairly expensive as well.
I would shim the balance cock , in case you don't like flipping end stones over.
I just see no point in fixing this a staff if it ain't broke.
I have nothing to show at the moment. It's stowed away in a drawer.20200307_195350.thumb.jpg.786365e034e82671706f71f609a452bf.jpg
This was when I just fixed the brushless sewing machine motor to the lathe bed. I'm only using for odd jobs and practice at the moment.
Ok, thanks @Nucejoe. I'll try flipping over the stones tonight  and see how it goes.
I welded a 0.7mm stainless steel wire to the jaws of an eyebrow tweezers. Hopefully it'll be strong enough to push out the hairspring stud.
Last night I tried getting the hairspring stud out of the hole again but it was really tight. I didn't want to risk damaging anything in case I the tool slipped, so I aborted the mission. I'll try again tonight after applying some acetone and WD40 to loosen things up.
I don't think the stud is friction fitted, as a large gap is visible around it. Also, there is a groove in the stud for the retaining screw.
I tried @Nucejoe suggestion of flipping the endstone. It definitely works. So I'll leave it for the moment  until my skill level catches up with the problem.
@HectorLooiyou can try flipping the balance cock over and press the stud down a bit to loosen the stud with a jeweling tool and a flat punch. You would need a staking block with small holes as the “anvil”. You can then press it out again from the reverse direction if it’s loosened.
Thanks. But I don't think it will work because the stud has a flange.
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
