2 hours ago, Daniel123 said:
Hi Guys,
 I’m looking for a second hand lathe motor, does anyone have any recommendations.
Thanks in advance
Dan
Get a sewing machine motor and a counter shaft
I’ve been keeping an eye out on eBay, so many makes out there. I’m hoping to not buy wrong thing
A lathe on a Borel stand with a countershaft and a sewing machine motor is the best setup. And make your belt out of boot leather for no noise. Here is one of my many videos.
When you see something is right, don't hesitate to ask here, or pm one of us.
There are many options, from single speed motors with countershaft to give a limited range of speeds, to variable speed AC/DC motors with or without countershaft, usually with a foot pedal rheostat to vary the speed, to more modern DC motors with variable speed, often with a knob to set the speed but could be with foot pedal or knob and foot pedal for on/off.
In my early days most lathes I encountered in the U.S. had the AC/DC "universal motor", mounted on the famous Borel base,with foot pedal, which is familiar to most watchmakers, and which I despise (haha). I hate not having a fixed speed, and those motors hate being run slowly- no torque- so a countershaft is really necessary in my opinion to step down the speed from a fast spinning motor.
DC with a proper control will give a very wide range of speed with plenty of torque at slow speeds. There are usually some DC motors with controler ready to mount up for sale on German Ebay, a friend got one and it is very nice. These tend to run very smoothly, and as stated, have plenty of power over their range, are quiet, and eliminate the need for a countershaft. Aside from the mentioned one that's offered as "for watch lathe", there are many industrial sewing machine motors available on Ebay, often marked as servo motor. A servo is just a DC motor that has a precision control. These tend to be overkill in size for a watch lathe, but there are smaller ones, and they tend to come complete with control. That would be far, far, better than the motor on your mother's sewing machine, which is usually a lower rpm "universal" motor, controlled by rheostat.
As for belting, that's a matter of choice. There are many options, from miniature V belt, to leather (which is fine), to fusible plastic/rubber belt, which is the choice of most folks I know, myself, and industry. If you have an industrial belting supplier in your town or nearby, they likely carry Habasit belting, which comes in a number of varieties of flat and round shapes. The round stuff is called Polycord and is very good. 4mm would be perfect. It's fused by cutting it to length cleanly, then put a piece of 1 or 2mm sheet brass (or steel) in a vice, and heat with a torch until hot enough to melt the belt. Press the ends on opposing sides of the hot metal, face to face, let melt, and slowly slide it off so the ends meet up. Hold until cool, then trim off the bead around the joint. I have belts joined like this that have been in use for a decade, zero issues.
In the pics you can see my primary lathe, the Leinen, with a 380v industrial 3 phase motor, with built in countershaft. That lathe had a motor integral to the base when bought, which was switched to a DC with control in the base, and finally I liked the industrial motor so much I pulled out all the DC stuff and have been running it this way for almost 20 years. The other lathe is a Favorite that my workshop mates use, it has a single speed (1400 rpm) motor, no countershaft, but 4 options on the pulleys, and they are very happy with it. The pic of the motor and controller is the one a friend bought off German Ebay (sells internationally). From the screwdriver stand you can get an idea of the size. Nice looking stuff, was under 200 bucks as I recall.
Edited by nickelsilver
I’ve been looking at this motor, it’s just motor though.
https://www.ebay.co.uk/itm/403592624860?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=zgke2qfwr92&sssrc=2349624&ssuid=rlz7vj34Rf2&var=&widget_ver=artemis&media=COPY
I'm jealous. What scope is that please Nicklesilver, I want to upgrade mine.
Is that by any chance a wolf hans JD, I'm in desperate  need of help with getting my headstock apart to clean my newly acquired one.
What size Wolf Jahn lathe is it? I just managed to dismantle my 6mm Wolf Jahn headstock
7 minutes ago, Neverenoughwatches said:
I only got as far as the back nut , wanted to speak to someone first before I went any further. It was a good ebay find  from a second generation retired watchmaker
Hope this helps
I think all of my lathe motors (5) are 1/10 HP--and they work great for me.  I am an amateur...btw.  This motor you are looking at is almost the same power, so I think it would be fine.
Hi lws. How do run your motors. fixed switch ?
https://www.ebay.co.uk/itm/265640776964?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=VyiznPFHT16&sssrc=2349624&ssuid=rlz7vj34Rf2&var=&widget_ver=artemis&media=COPY
how about this one
6 minutes ago, LittleWatchShop said:
I use Allen-Bradley foot pedals.  They are potentiometers.
Mine came with a foot pedal. It say John quale QD Beech and sons suppliers. How do you find working with a pedal as to a fixed switch ?
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
