400 day clock observation
LittleWatchShop
I serviced a Schatz a month or more back.  It has been running ever since, but I have observed recently that time seems erratic.  It is not the verge fluttering at mid position.  I think what is happening is that as the hands turn, the minute hand loosens up and gravity may be playing with me.
Does that sound reasonable, or am I smok'n something?
Here is a picture because everybody likes them.
Edited by LittleWatchShop
Hi LWS  your oservation is entirely feasable. What I would check it its connection on the front plate, the hour wheel/minute wheel are not slipping giving th same effect. Is the min hand tight on the shaft. If the escapement is operating correctly there are seceral possibles  the clutch on the center wheel, the engagement od the hour ans min wheel and the hand fitting its self.           Have a beer ar two and it wont matter anyway😆
I think the problem is the cannon pinion.  It has zero traction on the minute wheel post--zero.  That cannot be right, no???
I noticed this when I assembled the clock but thought that when the hand nut is installed it pulls the elements together providing the friction.
The way this works is the washer sitting behind the cannon pinion provides a backstop for the cannon pinion and when the nut is tightened, it joins the cannon pinion and the minute wheel arbor.  This must be tight so that the cannon pinion, and thus the minute hand, cannot freely rotate with respect to the arbor.
The clock that keeps on giving.  It stopped after running for a month or two.  I will investigate further,
In the mean time, I am questioning my suspension spring build.  It is the correct thickness for the Schatz 49, but now it appears that I assembled it too short.
I do not have the Horolovar book that gives the proper dimensions, but I found this on Mills Clocks UK.  Can anyone with the Horolovar book validate these dimensions?
2022-04-25 10_54_21-Schatz Standards 49 (Unit 6) Horolovar Anniversary Clock 400 Day Suspension Unit.png
On 4/25/2022 at 12:56 PM, watchweasol said:
Hi LWS  this is ascan from the page in the book. the images are the correct size and are used to assemble the suspension wires   hope this is some use. I
I installed a new suspension spring using the specifications from this page and it has been running for a day now.  My previous attempt was too short.  I did not see how far off the fork was.  At any rate, now it is looking good.
I am virtually certain that I used that book back when I was repairing clocks for my dad as a kid.  He must have let that book convey with his shop when he sold it because I cannot find it in his library.
31 minutes ago, watchweasol said:
Hi LWS  looking good , That book is invaluable when dealing with the 400 days.  fingers crossed.
Next time a 400 day shows up, I will buy it.  AND, I will charge my friend to cover the cost.  Right now I am fixing clocks and watches for friends for free.  Man, on man, I have so many new friends now!
You will find the 400 day clock repair guide book by charles terwilliger is a must if you encounter these clocks. Gives you all you need to know, the correct position of the blocks and the fork is vital.  The 400 day setting in beat tool is a must have as well. Its this tool.
I have seen it and considered buying it
  • 1 year later...
Hello! I want to repair my anniversary watch, but I can’t download the electronic version of the 400 day clock book anywhere. Help me, if anyone has a link or the file itself. Thanks for understanding!
1 hour ago, Dell said:
Mozart
What problem are you having because that’s all I restore so I may be able to help.
Dell
I have already mentioned to Mozart that I can't find  PDF of the book, and that he should buy it.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
