I mistakenly demagnetised a watch that was running (I read today you shouldn’t do this, correct?). And then it’s rate went to about -600s/d and it’s beat rate went to 4m/s, event to the point the timegrapher couldn’t read it.
now I can’t fix the issue.
any advice greatly appreciated.
cheers,
Boyd
I should recheck the watch for magnetism with a compass, sounds like you have inadvertantly magnetised it and its affecting the balance spring coils, take the back off and have a look at the coils when working  are they concentric and beating evenly and also flat.. Post pictures or a video of ithe movement.
I've always demagnetised running watches with no problems.
Check that the hairspring hasn't popped out from between the regulator pins.
Over the years I've had people tell me and I've seen it in print that it is very bad to Demagnetize A running watch yet I do it all the time with no problems except? The second part of the quota unfortunately applies make sure the hairspring is still between the regulator pins or make sure it's not caught on the regulator pins.
Or the basics look at your hairspring does it look right?
Thanks John!
Many thanks Mike, I’ll check!
Hi.
Given my minimal understanding of these things so take the following with a large pinch of salt, but given that a magnetised watch generally runs fast not slow, I wonder if someone in the past tried to slow down a fast running magnetised watch, then when the OP demagnetiser it, it would naturally suddenly run slow.
Obviously I may be talking out the back of my hat but it's a thought 😉
Theoretically you are actually correct. Oftentimes you'll see the regulator and watches pushed to the extreme to make up for a problem or perceived problem of timekeeping. Use of the problem is the watch desperately needs to be serviced. Conceivably a heavily magnetized watch could cause the same thing to happen.
On discussions like this where things aren't going in the direction they should be now is the time where additional questions are needed. Like the running watch what was it doing how well was keeping time. Then the usual one was the last time the watch was serviced and it would be nice to know what watch it is.
Also timing machine pictures it be nice to see a picture of the timing machine. Often times we may see or understand something that's not obvious to someone new to the use of the timing machine.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
