Hamilton Electric help please
Hello, and thank you for accepting me into the fold.
I have recently acquired a Hamilton Savitar II with a 505 movement. It was a non-runner though it would "power up" with the stem pulled and pushed in. The problem was it would run for about 10 seconds (+/-) and then stop. A new battery was installed and it still has this behavior of powering on, running for about 10 seconds and stopping. The mechanical side was checked for dirt in the gears, etc, but it doesn't appear to be mechanical in nature.
I'm making an assumption that the battery is delivering power and the electrical input is ok but somewhere between receiving the electrical power and running the watch there's a 'failure to communicate'
If anyone has an idea or can point me somewhere where I can dig into other ideas I would be hugely grateful
Thanks in advance
Maybe like any mechanical watch it's not that simple to just look at the gears. In other words what is the actual condition of a watch like the pivots and the oil used has it gone bad with time? Then for watch like this you really should have a service manual?
YES for sure.  It's likely the gold pallet contacts.
Edited by GomBoo
I didn't check for dirt, etc. My watchmaker examined the mechanicals, he's just not that familiar with these electrics to really get deep in the weeds with it. I do have a service manual that I found online but reading it I think it assumes some knowledge of the "flow chart" of these movements
Electric watches have unique problems.
First there is the electrical or electronic components. With a mechanical watch you look at things and see if they look good that doesn't necessarily mean they are good. But the electrical stuff you can't tell the condition that things are in.  This basically ideally means you have to have test equipment. There's specific tests on quartz watches and I know that the Hamilton watches have tests that should be made to make sure things are right.
Then all of the electric watches with gear trains have another problem. All of the gear trains have to be super free to rotate. Mechanical watch can plow right through a lot of dirt poor lubrication sticky lubrication at least up to a point. But a quartz watch for instance the wrong  oil can action cause the watch to stop and definitely give you problems. The balance wheel electric watch that balance wheel doesn't have a lot of power if this watch is never been serviced the old sticky lubricant would be enough to cause you issues.
More than likely your watch needs to be serviced. At least it runs for 10 seconds it's better than not running at all slats a good sign that's what's pointing at it probably just needs to serviced.
YES!!!  The fact that it runs & stops is a good sign...BUT, you do NOT want to keep trying to run it. The gold contacts will quickly burn thru. Best that a qualified Hamilton specialist do the service.
Where are you located?
Thanks, I'm in Denver, CO
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
