Hi to all Watch Repair Talkers.
I am a newbe! possible watch collector by default. Allow me to explain: I recently became a custodian of approx. 20 gents & 5 ladies watches. One of which is a Tissot Martini Racing chronometer, 1992 vintage. The back has a red hard plastic seal & is loose, not fitting properly. I fitted a battery, but is not working. The leather strap has had its day & needs replacing, but only if I can get watch working. The strap has unusual connections, ie: one narrow 2 lug 13.3mm width, the other like a Cartier single lug 12:7mm fitting.
Will continue later with the other watches.
Roy
Thanks for the intro @strrb, welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement.
I wonder if the plastic back was original on that watch. When I do an image search I only see metal backs and it seems that sometimes that case is involved in closing the circuit?
I suppose it's also possible that somebody already opened it up thinking it needed a battery and it had stopped due to needing a cleaning/lubrication.
That strap is unique - I hope you find one.
Thanks for the welcome. About the Tissot, a bit of misunderstanding here. I never suggested it had a plastic back. The back is stainless steel like most watches. It has a red hard plastic sealing ring, a bit like an O ring but a different profile. I assume the SS back needs to be pressed in after fitting a battery.The battery is held in place by a brass clamp with 2 screws, possibly to ensure a completed circuit .
As for the strap yes it is unique. Have contacted Tissot but replacement leather straps are no longer available. If you google this model, you will notice there are 2 lugs on 1 end, & 1 central lug on the other. If I can get this watch working, I will attempt to have a suitable set made.
Roy
When I first posted about the Tissot, I somehow titled the post Certina DS2 parts. So I have put the Tissot aside for the time being. So I am after a main plate for a DS2 manual wind, 25-66, calibre, ano day or date. My clock maker suggested I look for a complete watch, or movement that is not working, for parts. I found one on EBay, but did not seem to have the part needed.  Should anyone hear of know of any Certina parts, I would be extremely grateful. Roy
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
