Is It A No-No?
I am just wondering what view watchmakers and hobbyist have on the idea of buying old watches which have say 17 jewel movements, then cleaning it all up and placing the movement in a brand new case which perhaps was not the original style for the watch?
Also perhaps a change of dial and hands etc.
Is this sacrilege?
Or is this an acceptable idea?
I ask because I see many an old type watch on eBay that appears to have a decent movement but the watch as a whole seems tired and dated.
Am I wrong in thinking of this idea or does this already happen.
That is what people do with the Omega shom and the Seamaster 300 . They buy a 565 movement from and old Omega .Buy serviceparts from Cousinsuk or Ofrei . And build themself a new watch . Already happen is my answer . Thousands of times
Edited by rogart63
I picked up a Mido Chronometer at the weekend for not much more than old seiko money for the very same reason.It houses an ETA 2837 36000 bph offcially certified movement to 6 positions which was running 2 mins fast over 24hrs. Stripped cleaned and serviced and over the past 24hrs gained 0  and lost a mere 1 second.......1970's movement that is well worth re housing into a new case.
Also I have seen plenty of great watch tutorials but how do you go about cleaning a dial and the chronograph rings?
Is there a method or are these parts overlooked a bit?
Is there a good dial reseller that does unbranded dials, this is just another issue I cannot seem to find enough information about?
Any clues and links would be awesome thanks
    • Thanks Ross, yes i remember the broken arbor screw you had to deal with. Dont give up, if i can drill a tiny hole in a bloody hard barrel arbor without breaking the drill bit then you'll get that screw out one day somehow .
    • Isn't it most correct to say that the mixture of radium decay pathway compounds found in old lume will produce both alpha and beta particle radiation as well as gamma rays, so it's over-simplistic to dismiss it all as low-energy particle emission? True, a cheap geiger counter chirping away with a raw CPM count won't specifically give you the relevant biological dose, but it makes it easy to tell the difference between your local background, a watch with a bit of activity, and one that is comparatively quite active. Each person can make their own risk analysis based on their understanding and concern, but there's nothing wrong with using an inexpensive meter to help make the determination.
    • A lesson I learned last month on a Junghans pocket watch where both pins were bent over like stalks of wheat in the wind. I bent them back straight, wondering what a shock the thing must have taken to somehow bend even the outside pin over. And then the escapement wouldn't unlock at all. Probably the pallet stones are too long but I'm not ready for that repair yet so I bent the pins back over and it runs 0/0.2
    • Never. Brilliant work and photographs. Thank you. On my very first watch I knackered the arbour. I think the screw I put in was the crown screw. I didn't know about left handed screws then. Head sheared off. Thread broken just below surface. If I had the space, then a lathe would be my wished purchase. 2 1/2 years later and I still get the arbour out now and again and...... I can dream. It's a lovely pocket watch. Ah well.
    • Hello Davis. This thread is interesting. Thought I'd add my twopenneth worth. A short while ago I had a similar problem to you. Not a broken banking pin, but I did alter a banking pin. Much to the consternation of members. Rightly so. However I did as they suggested and obtained a complete donor movement and installed it into the watch. The client, who I did not charge but did the work as a project for myself, was as happy as Larry.  Can you not look for watch of the same name? A Donor watch or movement.  Keep us posted on your result please.
