Hi all,
I found this forum after I subscribed to Mark's online watch repair course. I have been devouring the episodes and can't wait to get started. So please excuse any daft questions for the first few months or so 🙂 I have had a fascination with watches for as long as I can remember and am very much looking forward to breathing new life into some old pieces. Thank you.
Rich
Oh I should add that one of my main motivators for learning to repair watches if to be able to restore my Grandfather's watch (Pictured). This is worth very little to the general public, but is of course priceless to me. It would be wonderful to see it working again. I will keep you posted on my progress!
Welcome to WRT forum Rich.
What caliber is under the hood?   In case you can not identify the movement will you post a picture of it.
=Hi there. I have just found the number under the balance. Very difficult to read, but I'm sure it says EB 8385-66. I've done some googling and it looks like an Ebauches Bettlach variety. I haven't ordered my tools yet, so excuse the fact it's not sat on a cushion 🙂
15 hours ago, grsnovi said:
Welcome Rich! I too just joined and I'm also quickly going through Mark's "Basics" tutorials.
Hi there and welcome. I've been looking through some of the other posts and so much useful information on here. I'm looking forward to learning so I can add value back to the group. Good luck with everything and be sure to post your projects for us to see 🙂
16 hours ago, Tiny said:
Welcome to the forum Rich enjoy your stay. Lots of really good advice from friendly members
Thank you Tiny. Very much looking forward to getting involved. I appreciate you saying Hi 🙂
Hello rich and welcome to the forum , If you Google "Ranfft EB 8385-66  the Ranfft web site will give you all the family variations and quite a bit of useful info.  I have attached a bit of reading for you to get you started.
1612608791_ToolsfortheHobbyist (2) (1).pdf 371.51 kB · 0 downloads TZIllustratedGlossary.pdf 4.2 MB · 0 downloads
Thanks so much watchweasol - that's very useful.
On 3/30/2022 at 1:51 AM, RichDavis said:
...be sure to post your projects for us to see 🙂
I've started with a few posts of my Elgin Grade 313 revival here.
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
