Spinning Hands
Willow
Hi Willow Just treat it loke a big watch. The platform comes apart like any escapement.  The attached document by David La Bounty takes you through it in easy understandable steps. Just be careful handling the bits they are very fine. If you havnt worked on watches/pocket watches before it just a case of taking your time.  If the escapement wheel just rocks when you move the pallet itpoints to a problem with the stones being loose or broken, but the acid test is to take it apart and check it out. Hope you find the document useful     cheers
Servicing a Platform.pdf
Thanks for that watchweasol not sure if i will be able to work on that, i have a tremor in my hand when i am concentrating that's why i work on clocks and not watches because the parts are so small, the document is very helpful i my give it a try if not will out source it thanks for you help
I looked at that document last night and it is very good it covers most things on how to service a platform. I didn't see any info on bluing screws or re-silvering a platform which is needed when servicing a visible platform in carriage clocks. but Willow you don't need that.
1 hour ago, watchweasol said:
Ys its ok to brush clean and not soak with isopropanol although using Ronsonol will be a cheaper option and just as good, whats the pallets like are the jewels intact and noe loose ?.  lubrocate it with watch oil, Windles clock oil might be a tad too viscous.
Yes the pallets jewels are intact and not lose and i have watch oil, thanks
well got the platform escapement back together and back on the movement ran for about 5mins and stopped pallets just rocking back and forth took it back out of the movement had a good look escapement wheel and pallets balance spring is good any ideas thanks
You have to have the right depth on the escape wheel which engages with the contrite wheel. You should have a screw adjustment on one side of the pivot of the contrite wheel, you also have a small amount of movement with the platform. Have you checked the teeth on the contrite wheel. When it stops mark it, start it again and see if it stops in the same place, if it does you know its a tooth that is causing it.
Will check did have a look at the contrite wheel will check again with microscope, would the pallets be rocking like that when its not back in the movement so its not connected to the contrite wheel yet
The pallet fork will move anytime the balance moves, in or out of the clock.
I agree with OH, this sounds like a depthing issue. It can be tricky to find the sweet spot.
Will have a look tomorrow, electricity gone off in the house 🏠 fault somewhere somebody coming out tomorrow to have a look from British gas
If you remove the balance cock and complete balance you can touch the pallets with(I suggest a clean not to thin oiler or peg wood) and watch the action, the escape should be clean and swift. As I have said before the movement should work no matter what angle you have it even upside down it should work. This is a good way of making sure the depth is correct on the contrite wheel to the escape wheel and the correct end shake to the balance. The contrite wheel should be loose to rotate but with no end shake, so no matter what angle the movement is at the depth is still the same.
Is it also worth removing the balance, putting a couple of winds on the main spring and making sure the power is travelling right the way through the train and there's no friction in the movement? Sometimes we focus too much on one area and not the whole thing. Something like poor end shake could be enough to stall it.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
    • Sorry to reopen a necro-thread (long dormant) - I have a Seiko Kinetic 5M42A that needs at least one coil, possibly both. Anyone know of any sources?  The usual fallback of eBay has failed me - there are people selling coils, but not the ones for this movement (which was apparently a very popular movement, used in Seiko and Pulsa branded watches.) The coil numbers are: 4002 516,  and 4002 519 I'd also love to find a source for spares of the screws used all over this movement - they're Seiko PN 0022 247 Thanks! (Moderator - if this should be a new thread, please do feel free to tell me, or drag this one into a new thread.) Don Eilenberger
