Hi
I've recently got a Cyma 265 automatic as part of a joblot of watches. It's missing the lower balance cap jewel, jewel and kif-flector spring. Does anyone know what size of Kif-flector spring it needs and also can I use jewels from an AS 1674 (even if inca spring setup)?
Cyma 265 seems to be rare so struggling to get parts.
Any help would be appreciated.
Thanks
To help others help you, you should post a picture of the top jewel, as well picture and measurements of the recess for the jewel setting on the main plate.
 Do you already have an incab spring?    if your looking to buy the parts;
Visit the page    AS 1674 ranfft  ,  Dr ranfft lists the entire family AS 1674 is a member of, a KIF flector off of any calibers of this family is your choice.
Good luck
Good luck
Thanks Nucejoe. The AS 1674 on the ranfft site is the Cyma 265 that I have. Unfortunately I have searched for the AS calibres listed but none have the KIf spring, all are inca. The Cousins site does have kif springs available so I will measure the recess for the spring first as JDM suggested.
I neither know nor think Cyma is the sole proprietor of Kif flector.
Venders of movements have the choice of shock systems so you are likely to find Kif flector system on other brands or other Cyma/ AS  calibers.
This only boradens the scope of your choices to other AS calibers as Dr ranfft lists them.
Correction   Broadens not boradens.
Also if you for example came accross Cyma 1565  kif flector, you have found kif flector spring that fits right onto the setting in Cyma1674.
Apologies for not coming back sooner, I was trying to get more information.
The cyma movement I have is the one listed on Ranfft:
I took JMD's advice and measured the recess for the Kif spring which was just over 1.4mm which would suggest I need the Kif 2-3.
Next question would be what does the BS stand for so that I can work out which cap and jewel I need?
I also found on the Jules Borel site that the balance for the Kif setup is an AS1140, although I can't find any reference to that movement anywhere. I was interested in this so as to determine which chatron to get as I believe there are different hole sizes: www.julesborel.com/cgi-bin/matcgi2?ref=AS_1674
Thanks
The problem you're having is the company used a base caliber and modified it. So this means it's not an exact match for the base caliber it's been modified which does present a problem for parts. Especially since all the references imply that it's exactly the same as the base caliber which obviously it is not.
On 2/14/2022 at 3:28 AM, dbanks866 said:
AS 1674
There may be another way to work the problem? But it's going to take some detective work and time. If you look in the physical bestfit book the 1674 base model is 1673. I noticed is actually several balance wheels listed for this? But once you know the base model pick a common component like the barrel or something is not the balance components escape will be good probably see which other watches cross reference to this and then start looking at those in seeing if any of those watches are similar to your watch. Somebody else probably did the same thing otherwise you look in the Kif block except the Kif book of course doesn't list your watch at all?
Yes there really is a Kif cross reference book it's about a quarter inch thick of the 16 series there is 16 seven 786 and 90 and then you go to 17,001. See if any of those look like your watch if they do I'll tell you what the part numbers are.
Thanks JohnR725. By accident I came across an Egin movement (884) which looked remarkably similar t the Cyma/AS 1674, although one movement uses inca whilst the other uses Kif Tior, I've attached the pictures. I presume then that they might have used Flector as well. On checking the Jules Borel site for interchangeable parts it is the same list www.julesborel.com/cgi-bin/matcgi2?ref=ELG_884 as the AS1674 from the same site. So maybe this is a good place to start my search? Unfortunately I don't have access to the kif reference book. Can you buy it? I did have a look at the Cousins Kif reference material but Elgin isn't listed.
image.png.081458762231af610a8945bf105765ea.pngimage.png.c599430f13af479cee74cd9148ad0a58.png
7 hours ago, dbanks866 said:
kif reference book
I'm not actually sure where you can find the physical book? I know where mine came from but that's not going to be helpful? I got mine when I went to the factory along with the kidded tools and some spare Springs. I don't know if you stop by the factory anymore whether they would do that and I was in a class at the time.
I know for instance the other spring that you don't have they have a website. Where they have all kinds of interesting information but I don't think Kif has the same thing?
Although cousins might have it if you look up Kif I don't know
http://www.incabloc.ch/en/pieces_rechanges.php
I think I've uploaded what you're after in this topic:
KIF shock springs
Thanks Plato! That's saved me a lot of time. I don't know how I missed that in that post as I thought I'd been through all the thread.
I was tried to approach it a different way in that I had noticed that the Elgin 884 movement had inca and trior options so I made the assumption that the balance bridge wouldn't be changed (rightly or wrongly) so looked at the kif cap and jewel ptions for the trior which matched the flector options, and then I went looking for movements that had the same specification. Turns out there are quite a few eg Tissot, Record, Bulova, and Hamilton to name a few. I had a partial movement from a Bulova 10BPAC and it had the chatron so tried this and it fits confirming at least that.
It looks like I'll be able to get some replacements from Ebay cheaply. I'll order some and let you know how it works out.
Thanks everyone for their input.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
